Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > Blogs > Big Al
0 Another Wrap Post
Last Post: Bryan1976
0 Chinese S&S carbs
Last Post: 11B40
0 Keihin Butterfly crack
0 2009 XB12R make over.
Last Post: salmanmr
0 Proper XLCH
Last Post: Magneto Sportster
Last Post: Gold Member
0 Top mount steering damper?
Last Post: salmanmr
0 What a birthday I've had
0 Ignition swap (compatibility?)
0 Problems relocating coil
0 Ironhead carbs
0 "03 vs 04+ Cylinders & Heads: Different Carb Bracket?
Last Post: screndname
0 Gearing Help
Last Post: BigMek
0 baker 6 in 2000 883 conversion primary vent drips
Last Post: Randy_rots
0 Fixing Digital Gear Indicator
0 Top end failure
Last Post: Mission1
0 Info needed on mini sumps.
0 Graduated to Ironhead
0 Inherited Ironhead
0 yost power tube guy
0 FDR Drive pothole did this...if u can believe it
0 Looking for an xlch engine
Last Post: Medyo Bastos
0 dieseling ? solenoid ? help
I will keep a carbon copy here of all my blog posts on my personal Cycle Blog @ http://mast3r7.blogspot.com/
XLForun.net only allows 4 pictures per blog post, so to see all of the images and details of posts, follow the links to http://mast3r7.blogspot.com/
I will write not only about what is going on with my current Sporty Project, but also about Lifestyle and HD ownership as well, enjoy.
-Big Al
The project has started, God Help me!
Submit "The project has started, God Help me!" to Facebook Submit "The project has started, God Help me!" to Google
Posted 23rd June 2010 at 08:10 by Big Al-1200c
To fill you all in, I had foot surgery on April, and have not ridden since. Hence the absence of post here. As soon as I am healthy enough to ride, I will be leaving on the next plane out to Afghanistan.
So I decided that since I can't ride, I am just going to do some of the work I had planned for the bike upon my return, now. In turn, keeping my mind busy and out of depression.
Here is the list of tasks on my checklist.
Install Running, Turn, Break light module - Done
Eliminate stock tail light - Done
Chop the rear fender - Done
Relocate License Plate
Paint Bike (In striping/prep stage)
Relocate Coil
Relocate Front Turn Signals
Install New Tires
The following blogs will be about the tasks above, feel free to ask questions and comments.
-Big Al
Views 4915 Comments 0
