Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > Blogs > Big Al
0 fuse block
Last Post: Mike1nw
0 Wet Sumping (No oil returning)
Last Post: FalcoFlash
0 Resto-Repair 84 ironhead
0 Air filter Q
Last Post: Billy1200
Posted On: 59 Minutes Ago
0 Can’t go over 70mph
Last Post: davesz1r
Last Post: maltesefalcon
0 73 XL 1000 Sportster - SOLENOID BYPASS
Last Post: Akdawg
0 ultima install without VOES
Last Post: supermotolew
0 TC88A Maps for 883 to 1275 Basic Converstion
0 Reflectors...Yeah, or Neh
0 Chinese S&S carbs
Last Post: T. Clark
0 Recent 1275 Dyno Tune
0 Hammer 560 VS 570 Felt differences?
Last Post: sportytrace
0 2006 XL1200 OEM Battery Dimensions
0 Swingarm has a slight twist
0 Cycle Cover for Sportster
Last Post: FiftySixer
merc, schvamf (48), MikeLightnin, o2man98 (40), Toadz (32), WingNut15B (32)
I will keep a carbon copy here of all my blog posts on my personal Cycle Blog @ http://mast3r7.blogspot.com/
XLForun.net only allows 4 pictures per blog post, so to see all of the images and details of posts, follow the links to http://mast3r7.blogspot.com/
I will write not only about what is going on with my current Sporty Project, but also about Lifestyle and HD ownership as well, enjoy.
-Big Al
Fender Cutting & Tail Light Removal
Submit "Fender Cutting & Tail Light Removal" to Facebook Submit "Fender Cutting & Tail Light Removal" to Google
Posted 28th June 2010 at 14:22 by Big Al-1200c
!The XLFORUM.net blog only allows 4 pics, to see all of the pics in detail, please click the link above to be taken to the original article.!
Now that the Run, Stop, Turn Signal Module has been installed, we move into cutting the fender.
Here is the digital muck-up I did, trying to decide where to cut the fender.
I removed the fender to remove the tail light and move the wiring and support bracket out of the way.
(IMAGE)
This is the Tail Light Base that contains the Circuit Board we need for later. Disconnect the wires and carefully pry it outwith your hands or a wooden tool.
(IMAGE)
Note on the picture to the right, that the fender support bracket and harness are in the way of the cutting line. The harness was moved back and will be relocated later, the bracket on the other hand, since I want to retain it for 2 up riding support, needs to be moved.
(IMAGE)
To do that, just flip it, so that it hangs towards the front of the fender instead of the rear. Now the harness support tabs notches are in this new location, preventing the bracket from laying flush against the fender.
(IMAGE)
A quick cut with the dremel and that is taken care off.
Now the bracket can lay flush against the fender.
(IMAGE)
Stand back, I have not dusted the ol' Dremel in a few years! (and I call myself a man?), so my hands are a bit rusty. I have to say I recommend a 3" cutting wheel instead of the Dremel, as that will probably take 5 minutes, took me 25 minutes with the Dremel. Use blue painters tape or similar to protect the cutting area, making sure it is tight and without bubbles. Use a pencil to mark your cutting line and measure to make sure you are even. All up to this point, you can change your mind and go back, but once you put the dremel to the fender you are committed, so make sure you got the line and contour where you want it. Once done, I used a stone to remove sharp edges and even out any imperfections.
The cut came out clean and straight.
(IMAGE)(IMAGE)(IMAGE)
Up next,
License Plate Relocation
Mounting the circuit board under the fender, plus routing the wires.
Paint
-Big Al
Views 12504 Comments 2
Total Comments 2
    Epyx's Avatar
    Good post, thanks for the effort. I am going to use this in the future. Not on my XLN but on a Yamaha project bike I may start working on some day.
    Posted 7th July 2010 at 11:49 by Epyx Epyx is offline
    this is a great blog I'm going to be doing the same hing to my 883 thanks for the info
    Posted 18th May 2011 at 14:19 by rikasso
