Last Post: mor
0 Weld-on Bungs and Mounting Tabs for Your Motorcycle Build
Last Post: BILLETPROOF
0 Swapping Iron 883 forks for Seventy-Two forks?
Last Post: Aden
0 THE Trainspotting Thread
0 Intermittent oil smoke from rear cylinder
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
WinXP (67), Maggie (61), grancan1 (53), SRKASM (47), metalmessiah, o113attitude (43), stinkynate (35), wingman_214 (34)
Rate this Entry
Flywheel assembly all done
Submit "Flywheel assembly all done" to Facebook Submit "Flywheel assembly all done" to Google
Posted 19th August 2012 at 07:51 by 62 Ironhead
New Jims pinion and sprocket shafts fitted, new bearings and thrust washers, S&S Heavy Duty Rod Kit, balanced and trued.
Posted in Uncategorized
Views 935 Comments 0
« Prev     Main     Next »
Total Comments 0
Comments
