0 Chinese S&S carbs
0 Info needed on mini sumps.
0 Andrews flowmaster carb on ebay
Last Post: stikflote
0 XL Forum T-Shirts ?
0 Don't Think I Ever Did This
0 04 brake upgrade question
0 Main shaft bearing preferences
0 yost power tube guy
0 "S" model specific Q&A
Last Post: DMC12
0 1966 XLH...sort of
0 FDR Drive pothole did this...if u can believe it
0 Hammer 1250
0 Primary Dip Stick?
0 Noise and rod play
0 Bikers choice main jet threads
0 Sportster 883 mini electronic speedo
Last Post: Doc308
0 41mm V-Twin Narrow-glide conversion for XL
Last Post: farmall
Last Post: Gold Member
0 Spark Plug Indexing
0 1992 XL ignition explained
0 Counterfeit Mikuni Carbs
Last Post: davesz1r
0 front exhaust pipe keeps slipping off, help
Last Post: 67170
0 Stairman question
debster, brknwng (72), TerryW (67), doc_davo (65), clh, Hanoverfiste (48), XL-DecentGlide (45), nobleff517 (45), joekangiser (42), scroggy (36), sgvrider (33)
Speedo.....final layout
Submit "Speedo.....final layout" to Facebook Submit "Speedo.....final layout" to Google
Posted 8th March 2015 at 01:52 by 62 Ironhead
I was never quite happy with how the speedo looked on my bike.
1st Position - was mounted using the standard bottom mount bracket and clamp, seemed to stick out a bit, looked too high and the angle was all wrong.
Tried mounting a few different ways, just didn't look that great.
Came across a mounting cup system and after a few modifications to the bracket it has now ended up looking like this.
Looks a lot better now and seems to keep the lines. Now to fix up all the wiring.
Views 31383 Comments 3
Total Comments 3
    Thats an excellent job your doing.
    The pics look like your in WA, is that right?
    Posted 23rd March 2015 at 12:01 by mariofleur mariofleur is offline
    62 Ironhead's Avatar
    Yep, WA sunshine
    Posted 25th March 2015 at 03:54 by 62 Ironhead 62 Ironhead is offline
    Im in Karrinyup. I bought a 1974 XL Sportster two weeks ago. Brought it home on a trailer. Its my new project bike. Ill buy you a beer and pick ya brains on your project.
    Posted 25th March 2015 at 07:07 by mariofleur mariofleur is offline
