Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > Blogs > Big Al
0 Muffler adventure and Uh-oh
Last Post: Mike1nw
0 When Were You Born?
Posted On: 44 Minutes Ago
0 Generator Blues
9 Help: 78-83' V-Twin Front Right Caliper and 74-77' Russell 51'' Brake Line
0 First XL - XLCH or XLS?
0 72 xlch is overcharging... bosch mechanical reg
Last Post: JB in NC
Last Post: 061275r
0 83 frame early 84 motor
Last Post: 84bobber
0 Allegheny 2023
14 Normany Beach:
0 Old man walks back into a forum..
Last Post: Phillober
0 Sportster tachometer wiring question
Last Post: sleighcrane
0 Wiring tachometer
0 2006 shifter shaft assembly on a 2004
0 Help insanely loud decel pop after 1250 kit
Last Post: DrMotorcycle
0 Any luck with baffles?
Last Post: cookiemech
0 Why are people so critical of the Sporty S/Nightster?
Last Post: OCRyder
Last Post: Racepres
0 Today's rant
Last Post: ReddTigger
0 Rear Motor Mount Blind Hole?
I will keep a carbon copy here of all my blog posts on my personal Cycle Blog @ http://mast3r7.blogspot.com/
XLForun.net only allows 4 pictures per blog post, so to see all of the images and details of posts, follow the links to http://mast3r7.blogspot.com/
I will write not only about what is going on with my current Sporty Project, but also about Lifestyle and HD ownership as well, enjoy.
-Big Al
HD Stop, Running, Turn Signal Light module (69462-06A) Install
Submit "HD Stop, Running, Turn Signal Light module (69462-06A) Install" to Google
Posted 28th June 2010 at 07:54 by Big Al-1200c
This one is a really easy;
Remove seat, disconnect rear fender wiring harness from main harness,
Plug in module female to male, male to female, tuck under frame members to make sure it will not kink or pinch when the seat is installed, zip tie in place, install seat.
Find the notches on the turn signal Amber covers and carefully pry them off, replace with Red covers.
Start Bike and test R-L signals, 4 way and break, then while holding break test R-L signals again and you are done.
If you have everything you need with you when you start, it should take no longer than 15 minutes, it took me 10 minutes from start to finish.
I am removing the stock tail light and bobbing the rear fender, so look out for my post on that in a day or two.
-Big Al
Views 8281 Comments 0
