0 1960 XLCH in the UK
0 my rear wheel
0 Another Sporty ADV Build
Last Post: 51 New West
5 What Color Helmet is Most Noticable?
0 Friction modifiers in gasoline
0 Adding fuel level sensor to the speedo/tach
0 Delete rocker box breathers or not?
0 clutch spring compressor
0 A Day in the Life...
Last Post: RDHenley
0 quick shifters
Last Post: gusm2
0 How much is too much?
0 Ironhead Oil Pump Gurus, come inside.
0 1976 Ironhead Top End Rebuild
0 520 conversion for ironheads
0 Trying to trace a seat part number ...
Last Post: neilp
0 Mid or forward controls.
0 Your Motorcycle Workspace/Garage
Last Post: duffy
Last Post: decman
Last Post: scooby
0 Sportsterpedia Progress
steve yorke (62), edman (54), Hudsonator (52), kozman32 (52), R3DN3X (50), gmcsid (49), mitch (44), Txngrg87 (33), Gotenfan (30)
Removed the Timken bearing from the sprocket shaft
Submit "Removed the Timken bearing from the sprocket shaft" to Facebook Submit "Removed the Timken bearing from the sprocket shaft" to Google
Posted 26th January 2011 at 07:06 by 62 Ironhead
I didn't have one of the bearing pullers as shown in the service manual to remove the Timken bearing off the sprocket shaft and bearing shops wanted over $100 for a suitable puller that I could of used.
So I took to my $30.00 gear puller and made a few mods so that the claws fitted underneath the bearing.
Before
After
Just filed the claws down a bit until they fitted under the bearing, removed the linkage plates from the puller and bolted the claws straight onto the threaded body of the puller.
Worked well, nice and easy.
Views 2900 Comments 1
Total Comments 1
    Baphomet's Avatar
    Nice work. I might have been a little concerned they be too thin and bend or break, but obviously it worked and save you some bucks. Plus your puller is still just as usable as ever. Brilliant.
    Posted 26th January 2011 at 14:41 by Baphomet Baphomet is offline
