Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > Blogs > Danny3nose
0 Oil pressure stays up 20min after shut of
0 Pinion and sprocket side bearing questions
0 Iron 1966 XLRTT
0 Bolts and Metal Type
Last Post: ericfreeman
0 883 rev range
0 Sidehack for XLS
0 S&S Super E
0 trans corner reinforcement 54-72
Last Post: Marsikus
Last Post: koolbreeze
0 passenger with driver's backrest
Last Post: Veeflys
0 Chain drive vss
0 yost power tube guy
0 oil filter stuck
Last Post: Bikeaholic
0 New Lifters with new cams with your conversion?
Last Post: yelladox
Last Post: TPEHAK
0 Ia 83 xlx
0 is a buell a harley
0 Hawkeye's 1275 Hammer Performance Conversion
Last Post: hexnut
0 how to reduce buffering
Last Post: Stude
0 Proper XLCH
Last Post: revjen45
5 Poll: Milwaukee-Eight Sportster Engine Size
0 73 xlch gas flowing from carb
Smelly cat, smelly cat...
Submit "Smelly cat, smelly cat..." to Google
Posted 20th January 2008 at 08:36 by Danny3nose
So somehow a stray cat has found its way to my mother's front porch. She's been putting food and water out for him, and she put a little cat carrier box outside so he could have some shelter from the elements.
The cat is a gray tabby and is pretty fat, so I figured he had a home and his owners just let him out for awhile during the day.
Well this weekend the temperature has dropped to below zero with the wind chill. As I was trying to reassure myself that the cat is fine and is probably in a warm house somewhere, I went downstairs to smoke a cigarette. My basement was freezing. At that point, I realized that if it's that cold in my house, imagine how cold it is outside. So at 3am I decided I had to drive to my mom's house to check on the cat.
There he was in his little house, looking cold and miserable. At this point my heart about broke and I went inside to find a space heater. I plugged it in outside and pointed it towards his cat carrier. He's a wild cat, and I can't get near him or he'll run away. So as I put the heater on the porch he ran to the edge of the porch to watch me. I talked to him in a quiet voice to try and sound comforting. Then I went inside and found some hand warmers. The hand warmers are the kind that last for seven hours, you open the packet and once they're exposed to air they start to warm up. I put them in his house and went back home.
I'm hoping he finds his way back to his house so he can keep warm. He's very timid, so I had to leave or else he wouldn't go back to where the warmth is.
So now it's 3:30 in the morning and I'm still awake worrying about a cat.
Views 4070 Comments 2
Total Comments 2
    Casper's Avatar
    Hey, you gave it a chance; that's all you can do. At least you didn't pull the same stunt that some schmuck in Dallas did (see article). Hopefully the cat will find its way back home soon enough.
    Posted 20th January 2008 at 15:09 by Casper Casper is offline
    olderthandirt's Avatar
    So your saying you still couldn't get close to any pussy?
    Posted 23rd May 2008 at 03:45 by olderthandirt olderthandirt is offline
