Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > Blogs > Sporting Lad
0 Keihin carb…mixture screw
Last Post: JB in NC
Last Post: JB in NC
0 1st gear clutch squawk
Last Post: OCRyder
0 supply and demand
0 73 XLCH help
Last Post: JB in NC
0 Seneca Shadows WV. Sept. 5th to 8th and maybe beyond.
Last Post: JB in NC
0 Major update forthcoming
0 Vacume gauge questions
0 Rear wheel offset?
0 Question about our school systems
0 Ran out of gas.
0 Hello from Cape Cod
Last Post: xena
0 New to Harleys
Last Post: Dusz
0 1983 Ironhead! No Spark
0 What engine oil do you use?
0 Turn signals won't work when cold
Last Post: Debute23
0 Cafe' Image thread WTFN
Last Post: tigger
0 2013 XL883L Electrical Question
moe (79), demgdaj (73), Playtoe (68), shanneba, Charlie Allen (64), the cowboy way (64), P-Diddly (61), Utahsporty (60), evo-pete (59), stf420 (58), NevadaRob (56), Punisher (54), Razor_Reznor (49), Paycheck (46), jfs92579 (44)
DIY lower your headlight
Submit "DIY lower your headlight" to Google
Posted 31st December 2008 at 18:50 by Sporting Lad
Here's an easy and inexpensive way to lower your stock headlight if you have a classic eyebrow and don't feel like messing with your lower triple clamp or flipping your light upside down and wotnot.
It's really a variation on the popular "Xena mod" for instrument location, except upside down. I was just fooling around in the shop today, and I saw this in my mind's eye and said, 'Why not give it a try?' It worked.
http://xlforum.net/photopost/data/50...Dec_08_004.jpg
My version integrates a bracket used to move the headlight forward 1-1/2" to accommodate my Rifle Roadster fairing, but I can't see any reason why you couldn't do as I did, but without the bracket. You'd need to run the bolts in from the underside, since it's the upper part of the triple clamp that's threaded. Go now and examine your own for confirmation.
I used the same "long" 2-1/2" x 1/2" sockets (Craftsman ) that I'd used for my (earlier) version of the original Xena mod (when I ran drag bars).
All I've really done is extend the bolts suspending the light using the sockets as sleeves or spacers. Now, admittedly, the arrangement looks a bit... spindly
but, when you tighten that sucker down, it's as sturdy as all get out, i.e. it's
rock solid! I used nylocks for nuts. As with all H-D attachments,
check regularly for tightness. "WARNING: Failure to do so may result in injury or even serious death."
I'm not sure if I'll keep it this way (I'm forever rearranging things). Lowering the light does expose a lot of that messy wiring which would need to be tidied up some. But if you don't like your OEM light in its existing location, here's an easy way to lower it. Of course if dropping it 2-1/2" is too much you could always use std length sockets, or even tubing cut to your needs.
And here's the rest of the pics:
Views 15648 Comments 0
