But I can take a shot at the filter thing at best. The volume pulled into the chambers is controlled by the cylinders. What is seen inside the filter area is outside to inside differential (aka vacuum) via the cylinder fill like you mentioned. The restriction of the media makes that higher or lower differential until the cylinder is full. Then it equals out. The size of the filter is the same as the size of the breather bolt hole. A smaller filter makes for a smaller volume of air to manipulate (increasing the air speed thru the filter) While the larger one allows for a larger volume of air to be displaced at the same cylinder fill rate (lowering the air speed thru the filter) It's up to the media as to what speed it will allow thru it at what restriction rate. The restriction goes up as oil saturates the media. A K&N type media lessens the restriction due to the larger hole surfaces thru it (lowering air speed). Undoubtedly, it's the less restriction (lower air speed) that the engine likes the best. ? Easier less restricted fill? My SBC runs and feels better with faster carb response with the larger A/C. Maybe that's the media restriction of the smaller A/C that it doesn't like. My vacuum secondaries always liked the bigger A/C. |
i think we are on diff tangents.
taking a break from the heat/humidity, building a new shop or second shop, why i ask, geeeez at 68 i think i know when to quit. looks like i have chicken pox, hate those 6010 rods doing over head up hill. the forum has reduced past post on our page so i can't clip/paste. your are def on track with something you said eariler, was hope for you to expand it because i think you are absolutely right. post #32 |
Many of the old quadrajet equipped cars came from the factory with single snorkle air cleaner housings. There was enough restriction they wouldn't open the secondary air doors. Flipping the air cleaner lid made a huge difference as it allowed the secondaries to open. |
That makes sense.
Heh, my lid's flipped as we speak. The assembly is taller than the stud... I did open it up last weekend and the secondary's did well... I'm running an Edlebrock at the moment. This motor's too small for the 750 Holley. Last motor liked it but the float was set at the lowest point plus about 1/2 of a thread. I know, street motor, but it's all that vice I have left. :D I haven't thought a lot of the affects on the Sportster carb from A/Cs. Obviously, there are gains from running the vent lines elsewhere. As well as cons I suppose. |
Not routing the breather into the intake also keeps the throttle blade and the throat area right where it closes cleaner. They will get a crud build up that needs cleaned periodically or they develop off idle issues. |
Frankly, I'm not sure where I've been either. :coffee The piston squirters added more oil in the sump ... No they didn't, sort of. The only thing the squirters did was add the same volume of oil in the sump at a faster rate. Feed / scavenge gerotors are the same size before and after they started using them. http://sportsterpedia.com/lib/exe/fe...hippysmack.jpg http://sportsterpedia.com/lib/exe/fe...hippysmack.jpg Yin-Yang: Faster oil rate in the sump without added air means it needs to move air out faster to keep more amounts of oil from coming into suspension? More oil in the sump at once gives to more suspended oil (or thicker air/oil mist) on upstroke. Thus the smaller holes in the bolts for faster air removal before suspension. :geek |
I finally got all I wanted done to the engine and got her running good. So I got a decent base to start with on an A/C mod. Just makes it easier when figuring changes. I haven't run a SBC vent into the carb since I was old enough to buy my first shiny chrome assembly. :) 2 things creep out of memory are cleaning out gunk from quadrojets and scraping Quaker State glue out of the valve covers. But the Sportster engine is a good size learning curve from my shade tree education. So I guess I've been taking baby steps. |
mr. folkie i used to be able to go way back on the posts but now only 4 pages are shown. i am sure everything is still there, just have to search in a diff way.
storm coming, check everything out, for sure my generator. i'll have to get back to the thread, but a passing thought there mr. hippy: rethink the breather orifice effect. it sorta goes hand in hand with another observation you made. since i can't clip & paste, will use a method that mr. folkie uses and type everything in a word processor and then clip & paste so you do not time out on the forum. |
