-   Sportster Motorcycle Tires, Wheels, and Brakes (http://xlforum.net/forums/forumdisplay.php?f=206)
-   -   Mystery drip off rear brake cylinder (http://xlforum.net/forums/showthread.php?t=2073792)
BluesandBike 17th June 2019 14:29
Fluid is dripping off the rear brake cylinder. Mechanic tried twice to locate/tighten and then replaced the cylinder and hose, still dripping. I am wondering how it can still be dripping. Is it possible there is a fluid leak higher up dripping ONTO the brake cylinder?
At my wits end over this.
09 Nightster.
bustert 17th June 2019 15:08
first of all what kind of fluid
BluesandBike 17th June 2019 15:36
I thought brake, mechanic thought brake, on my finger it’s black on a paper towel it’s more clear like brake fluid. I check the brake fluid level, but the drips are not a leak, so I dont see the level change. I took a picture the first time, am unsure I can post a photo as non-paying member
IXL2Relax 17th June 2019 23:26
You need to host the picture on a picture hosting site - get the [IMG] coded link and paste that into your post editing here - the picture will show up in the post...
Toejam503 18th June 2019 00:20
Could be coming from the left rear shock.
rocketmangb 18th June 2019 03:20
Engine oil from the drain hose ?
xena 18th June 2019 18:53
Good possibility.
This has happened more than once on my Sporty.
old dog 18th June 2019 19:22
over filling the fuel tank and dripping from the vent pipe
