-   -   Ironhead Shovster build take2 (http://xlforum.net/forums/showthread.php?t=2077210)
billeuze 20th September 2021 15:30
Originally Posted by forqueue (Post 5917065)
'Ridge' around the main-shaft bearing on 1- side has been ground-down. For kick-start gear clearence?
https://ibb.co/6n4qQ06
Yes, for kick start clearance
RicThompson 20th September 2021 17:26
Since you decked the cylinder you will want to check your head bolt length. If they are too long they will bottom out in head before the gasket is compressed. Also I ran 93 octane in my Shovelhead with 12 to 1 compression and never had a problem. It was dual plugged and single fire.
Maxeffort 20th September 2021 17:36
Great to see the continued progress!
billeuze 20th September 2021 18:12
Thanks for the tip Ric, and yes, my head bolts are a bit too long now. I have some much shorter bolts I’ve been using for all this testing/measuring assembly/disassembly but it is definitely on my list to cut down my real head bolts before installing for real.
RicThompson 20th September 2021 19:47
You may have to "fit" your intake manifold now also. Not a big problem if you are using bands.
billeuze 28th September 2021 04:59
Very little progress this past weekend. Partly because I distracted myself with creating faux patina on engine cases. I finally convinced myself to forget about it and install the engine in the frame. So here it is:
https://i.ibb.co/GMB9s6g/z5-engine.jpg
Other than that, just a couple of small tasks. I cut down my headbolts to accomodate the decked heads. Also I trimmed my pistin pin buttons to the recomended .06" float as I had only 01". Thanks to Chuckthebeatertruck for letting me know about the buttons needing clearance in this thread: http://xlforum.net/forums/showthread.php?t=2080234
https://i.ibb.co/yf5LhVp/z4-buttons.jpg
RicThompson 28th September 2021 19:20
looking good.
Tim The Grim 28th September 2021 20:42
Or…you could do what I did.
https://postimg.cc/gallery/K20J7k3
(Shameless self aggrandizing)
RicThompson 28th September 2021 21:51
Precision.
billeuze 5th October 2021 05:10
painted my cylinders and heads this weekend. cylinders only had a few bare spots where I ground fins for some clearance but I painted them completely anyway. The heads had been welded in various places so had a lot of bare spots. All cleaned up and masked here, then painted:
https://i.ibb.co/N73SkmV/a-01-masked.jpg
https://i.ibb.co/sF5fbGR/a-02-painted.jpg
https://i.ibb.co/QdqHtHw/a-03-painted-done.jpg
That was yesterday. Now they are in the oven giving the paint a heat cure.
