-   -   Ironhead Help me identify this bike (http://xlforum.net/forums/showthread.php?t=2076251)
AKL1 2nd April 2020 18:12
I've just bought the bike.
The engine says 66H2824.
Is it a XLH?
https://ibb.co/TLDvMk2
needspeed 2nd April 2020 19:00
No, it's not an XLH.
Assuming it's the original cam cover.
That multi ribbed cover was used in 1968, '69 and '70.
It's not a 1970 because the vin would be between the front cylinder tappets.
A '68 and '69 XLH came with electric start. The cover is not an electric start cover.
The bike has a xlch oil tank.
Looks like you've got an XLCH with battery added, magneto removed and converted to battery-points ignition.
A left side picture would have made this ID easy.
The VIN is not in the right format for a '60s sportster.
AKL1 2nd April 2020 19:07
https://ibb.co/80r1sVk
GA_Ironhead 2nd April 2020 19:26
Post a closeup of the 'VIN' pad.
What are the case belly numbers?
brucstoudt 2nd April 2020 21:51
XLCH tin primary cover.looks like a nice one.
Moon Wolf 2nd April 2020 22:46
I see parts from a lot of different years. It's hard to determine what year the motor might be, but it appears to be a pre 70 XLCH or possible a pre 67 XLH. Are you sure you've copied the engine number correctly? The number you've given us is not a Harley number. For instance, a correct number would include the complete model designation: 66XLH 2224 or 66XLCH 2224
sleighcrane 2nd April 2020 22:52
Could it be the elusive swap meet special?
AKL1 3rd April 2020 06:52
I´m absolutely sure. The engine no. says 66H2824
Parker 1000 3rd April 2020 14:05
I wish my garage was as neat as yours!
rejeanprimeau 3rd April 2020 14:06
Made with some tears from the owner who saw it disappear.
