-   Sportster Motorcycle General Discussion and Problems (http://xlforum.net/forums/forumdisplay.php?f=39)
-   -   Horsepower Guess (http://xlforum.net/forums/showthread.php?t=2073311)
razorbacksrule 9th May 2019 02:08
Horsepower Guess
Thinking of buying another Sportster . It's a 1999 883 with a S&S 1200 conversion S&S Super E carb Ultima Ignition and aftermarket Exhaust . What could I expect horsepower wise around 70 hp ?
Hopalong48 9th May 2019 02:12
Make a dyno pull part of the deal. then you will know everything you need.
Sent from my SAMSUNG-SM-G891A using Tapatalk
razorbacksrule 9th May 2019 02:37
Closest dyno to here is 70 miles away that's probably not going to
Happen .
Hopalong48 9th May 2019 02:53
A stock 883 from that time made about 45 hp. so a 1200 kit with good heads and cams could bring it up some. But just putting the parts on doesn't guarantee the hp you would like it to have. But its a start. the most important thing is how much do you like it.
bustert 9th May 2019 03:01
got a really good smart phone??
they usually have an app for that!
you can use the accelerometer function to calculate the numbers.
razorbacksrule 9th May 2019 03:10
I was basing 70hp on a 883 I done a conversion to a few years ago . It had an SE 1200 kit SE Ignition and SE slip on Exhaust . It pulled 72hp on the Dyno .
hammer6315 9th May 2019 03:27
Sounds about right. Are you happy with the performance?
RussW 9th May 2019 04:00
Check to see if the conversion was by installing one of the "74XLSS" kits, which included their Super Stock heads, Super E , 500 cams, etc. It would say "Super Stock" right on the heads. If so, you can figure low 80's with a marginal exhaust, high 80's with a good exhaust. Mine pulls mid 90's after changing to a Woods cam
