-   -   Ironhead Shovster build take2 (http://xlforum.net/forums/showthread.php?t=2077210)
Iron Mike 12th January 2022 23:30
Perhaps tap it for NPT?
wedge 12th January 2022 23:30
Originally Posted by billeuze (Post 5932478)
the surface around the hole is not perpendicular to the hole si I can’t use a copper or nylon washer to seal the bolt head to the came cover. So I used a longer bolt and a short length of 5/16 ID rubber fuel line to make a seal. The hose clamp is just to prevent the piece of rubber hose from expanding and sliding off of the bolt head. Probably not needed, better safe than sorry.
Oh, good idea. That will definitely work. You could also use a counterbore in a hand drill to square that up some but it may not end up square enough and your method is fool proof.
Thanks for posting this, I am enjoying your work.
Tim The Grim 2nd February 2022 03:22
I thought this was appropriate…
https://i.postimg.cc/hP6NcDwr/A74233...4-DE4-FD75.jpg
I hadn’t seen this one before. I wonder if he went through the fine details you’re doing.
billeuze 2nd February 2022 04:14
Cool, and he probably had more details to worry about than me!
billeuze 2nd February 2022 04:17
Yeh, that's what I was setting out to do. And I dropped my last 1/8" pipe plug on the floor and it bounced and rolled and lodged itself into a crevice somewhere that I just can't find. So I used what had on hand.
billeuze 2nd February 2022 04:37
Now where was I? A month ago I put the engine back in the frame, for the last time I hope. I had a few life interruptions the past month but did get my cylinders back on.
After this discussion: http://xlforum.net/forums/showthread.php?t=2080406 I decided to put my cylinder base nuts back in and use the allen nuts that Needspeed turned me on to. Here they are:
https://i.ibb.co/d6dZz7W/05-jugs-On.jpg
Then I clayed the pistons one last time just to be safe since the last few times I did it I had the cams installed one notch off. The clay turned out just fine, still lots of room. After the clay inspections I put the heads back on for what I hoped would be the last time, lined it up with the intake manifold and tightened up the bolts good and solid
https://i.ibb.co/Cb5w6Qs/06-intake-Fits.jpg
Well it turned out I couldn't get the clamps on over the intake manifold. They just would not get past the top cylinder fin. So it was off with the heads again to do a bit of grinding:
https://i.ibb.co/85y9h2Y/07-Jugs-Ground.jpg
A bit of touch up paint, heads back on and now the intake clamps slide on nicely and I'm ready to move on the the next step. That'll probably be the transmission since it is so, so close to being ready.
https://i.ibb.co/SXqsftY/08-intake-Clamped.jpg
brucstoudt 2nd February 2022 21:50
does that manifold use double o-rings? mikuni carb with that manifold?
billeuze 2nd February 2022 22:07
I think that kind of o-ring is called x-ring. The manifold is normal, it takes a regular o-ring as well. I am just using the x-ring type here.
And yes it’s a Mikuni hsr 42 going on it. I ran it before on the1000cc ironhead. I didn’t know the carb was too big for that bike when I bought it. Even so it ran a LOT better with this mikuni than it did with the old stock carb. Now on this engine it’ll be just about the right size carb.
brucstoudt 2nd February 2022 22:21
copy that bill.
Rogotek 4th February 2022 07:40
Hi Bill and the forum guys
Originally Posted by billeuze (Post 5936253)
I think that kind of o-ring is calked x-ring. The manifold is normal, it takes a regular o-ring as well. I am just using the x-ring type here.
Just clicked onto the forum after many years of absence - great to see your shovester evolving you may recall I have a project Shovester went the re phasing of the rockers (EVO rollers) and by shuffling valve stem heights and lash caps got the geometry acceptable bike is at where you are today just about their liken the post got me fired into finishing it Cheers Chris check Rogotek past posts will try and post shots
