-   Rubber Mount Sportster Motorcycle Talk (2004-2006) (http://xlforum.net/forums/forumdisplay.php?f=8)
-   -   Rubbermount_EVO muffler balance pipe (http://xlforum.net/forums/showthread.php?t=2076154)
stikflote 21st March 2020 18:13
Hi all,
i want to change my mufflers , in the book it says use a new gasket ,
but what keeps muffer connected to the cross over pipe ,
i need to swap them for some quieter ones
Keith
oldboy 21st March 2020 18:48
The crossover is bolted to each muffler and bolted to the engine. Do you have the stock mufflers? My stock mufflers were quite, How about the FSM?
stikflote 21st March 2020 18:56
@oldboy, YES think i do have the stock mufflers, at least ones that were on bike ,
how are the mufflers bolted to cross over pipe bracket?? ,i dont have a FSM,im using a
CLYMER manual for 2005 XlC 12OO
motorfish 21st March 2020 19:27
There is a flange on each muffler, bolted to the crossover's pipe bracket.
Needs 1/2 inch socket and flat spanner to undo the bolts. Loosen the headers at the cylinders before removing mufflers, to unseat connection to the crossover pipe.
Folkie 22nd March 2020 11:43
You're going to have a job to find anything quieter.
What do you mean: 'how'? With screws, through the bracket and into the muffler.
Get yourself the proper manual. :rtfm
stikflote 22nd March 2020 12:21
I hAVE Asked one HD shop about one they said they dont have any ,
,if any one in UK can tell me where to get one, or have a used one
to sell me please let me know
stikflote 22nd March 2020 12:47
https://i.imgur.com/95SSFpd.jpg?1
im talking about the flange on muffler not cylinder head flange
its got no bolts threw it .i cant understand what it does
Folkie 22nd March 2020 12:49
Part #14 is the screw that screws the muffler to the crossover pipe.
stikflote 22nd March 2020 13:06
No not that bit, in middle of muffler is a round stub sticking out, which goes between no 14 and 17 into that 1 inch
Folkie 22nd March 2020 13:18
'That bit' (screws #14) is how the muffler is attached to the crossover pipe.
The crossover pipe fits into the crossover port on the muffler. This is what allows the crossover to work. There is gasket that fits in the port on the muffler, which the end of the crossover pipe presses against to seal it. This joint is held together by the muffler being screwed to the pipe/bracket (screws #14).
