-   Sportster Motorcycle Air intake, Carburetor, EFI, Fuel, and Exhaust (http://xlforum.net/forums/forumdisplay.php?f=34)
-   -   Rigid_EVO Idle speed screw thread size (http://xlforum.net/forums/showthread.php?t=2079921)
LenC 2nd August 2021 23:08
What please is the thread size of the CV idle speed adjustment screw?
Mine just left to join all it's cousins in the dark recesses of my shop.
krono 3rd August 2021 05:57
Seems to be metric, maybe a M4 or M6 , just go to hardware store a purchase some, they are cheap... then come back and tell us what size it is, because I searched the internet all around for it and there is no info about it, only the part number P-N 27130-90
https://i.postimg.cc/qB6fLFqX/imagen.png
Hippysmack 3rd August 2021 05:58
If you are talking about the idle screw (not idle mixture) I haven't found it yet.
I measured mine at .154" with a 36 TPI (36 matches to a #8 screw)
But the standard OD on a #8 is .164".
I don't have a metric scale but converting I get 3.9116mm.
So I don't have an answer, just relaying what I measured.
But the carb was made in Japan, most likely metric.
I'd try a M4 x 0.7 (standard OD is .157")
Hippysmack 3rd August 2021 05:59
Seems we came to about the same conclusion.
Folkie 3rd August 2021 09:48
It's definitely an M4. I replaced mine with a stainless steel one. I used a 25mm cheesehead screw, and shortened it to 21½mm long.
That's metric coarse thread: 0.7mm pitch.
LenC 5th August 2021 18:04
Scrounging through some parts drawers I found an extended adjuster screw
and never did bother measuring so still don't know what size it is. :dunno.
Hippysmack 5th August 2021 18:23
Folkie 5th August 2021 19:52
It's the size I said it is. :rolleyes:
