-   Frame Mount EVO Sportster Talk (1986-2003 models) (http://xlforum.net/forums/forumdisplay.php?f=270)
-   -   BETTER Brakes for $214 (http://xlforum.net/forums/showthread.php?t=2006986)
Alexintenn 4th March 2017 00:36
One of the things I haven't enjoyed about my 87 is how week the front brake is. Honestly I think the bike borderline dangerous to ride with the stock brake.
It gives "panic braking" a whole new meaning. :laugh And I have new SS lines and new pads with a good blead.
But I'm coming from a sport bike backgound where two finger braking is a norm.
SOOOO I did a little research and found this.
http://i616.photobucket.com/albums/t...301_193443.jpg
I checked again and the manual does call for DOT 5 brake fluid which surprised me.
http://i616.photobucket.com/albums/t...301_201917.jpg
A trip to Autozone for the last bottle they had of this.
http://i616.photobucket.com/albums/t...301_201649.jpg
Another trip to Lowes for a 1 inch and an 1 1/2 in bolt and some washers and this was all the tools it took to do the job. Well these two wrenches and a Mity Vac. If you don't have one I recommend it :)
http://i616.photobucket.com/albums/t...301_214009.jpg
It only took a few minutes work and I had this done.
http://i616.photobucket.com/albums/t...301_231550.jpg
Unfortunately the weather was a lot colder today and it will be tomorrow before I can test. But I have faith that it will be a great improvement. I asked the Wilwood engineer and he stated flat out it will work fine with the stock master cylinder. This a 4 piston caliper and it will have to have more clamping force that a single cylinder sliding pin design.
Tomorrow's ride will let me know how much better.
If anyone else is interested
http://www.wilwood.com/Calipers/Cali...no=120-7737-BK
GP310 Motorcycle Front
Wilwood's GP310 motorcycle disc brake caliper has been designed and engineered for use on 1984 to 1999 Harley-Davidson® Motorcycles. Built around a 4-piston, high performance powerhouse, this billet aluminum caliper brings distinctive, bolt-on styling: Direct leg-mounted calipers are available for all single and dual disc models (except Springer and 4-speed FL models), as well as the 1983 XR 1000.
Mosey 4th March 2017 05:32
Good write-up! Let us know how it stops.
einheit 13 4th March 2017 13:27
upgrade to a floating rotor
Tom 4th March 2017 14:34
Hard to tell from your pics but those look like un-graded bolts,definately not good for anything critical on the bike. You need grade 5 or 8 bolts.
http://www.mytractorforum.com/attach...1&d=1294071220
Alexintenn 4th March 2017 14:49
Tom your chart doesn't include stainless steel bolts.
That's what I try to use almost anytime I install new fasteners. Do you have the numbers handy for that kind of bolt?
Tom 4th March 2017 15:09
Alex, I'm almost positive the bolt grading standard applies to stainless bolts also.
Any good hardware store like Ace or True Value will have a wide selection of bolts in all grades and thread pitches. McMaster-Carr has a great web site for hardware. https://www.mcmaster.com
*EDIT*. I just looked and stainless bolts do have different head markings, so if you have high strength stainless bolts you're good to go!
Alexintenn 4th March 2017 19:37
Tom Your question made me curious so I did more research and found out it is difficult to get exact info on how strong a stainless bolt really is.
BUT I found this info on
Bolt Depot website
It is a common misconception that stainless steel is stronger than regular steel. In fact, due to their low carbon content, many stainless steel alloys cannot be hardened through heat treatment. Therefore, when compared to regular steel, the stainless alloys used in bolts are slightly stronger than an un-hardened (grade 2) steel but significantly weaker than hardened steel fasteners. Unless great care is taken, stainless fasteners are susceptible to seizing up during installation, a phenomenon known as galling.
So Sir you are correct!!! I need to replace those with Grade 8
BigMek 4th March 2017 19:56
You can also use socket head screws (the kind that come with that black finish) since they are at least as strong as Grade 8, usually stronger. Fortunately they come in chrome since the black oxide is neither attractive nor waterproof.
Edit: Grade 8 is minimum 130,000 psi yield 150,000 psi tensile, alloy socket head cap screws are minimum 162,000 psi yield 180,000 psi tensile. If anyone was interested in actual numbers.
Alexintenn 4th March 2017 20:49
Grade 8 replacement done before I even test rode it. THANKS GUYS :-)
rejeanprimeau 4th March 2017 21:41
The metric numbers divide by 6.9 willl give you strengh in psi x 1000
