-   -   Ironhead Long intake (http://xlforum.net/forums/showthread.php?t=2075692)
dodgetrucken 21st January 2020 22:03
Long intake
Has anyone use one of these? I was thinking to help with atomization & put more power at the lower rpm. I have drag pipes lol & know the only real solution to drag pipe sag is throw them in the trash & put something with mufflers on. I wouldn't mined if I could fined a set I liked. I have a stock carb for my 64 but I already have a s&a E carburetor so y not. https://uploads.tapatalk-cdn.com/202...5d8c246345.jpg
Sent from my SM-N960U using Tapatalk
bustert 22nd January 2020 00:04
adding more plenum volume does have benefits but the 90@ turn will probably negate it.
dodgetrucken 22nd January 2020 00:15
Alright.
dodgetrucken 22nd January 2020 00:16
Even that much of a 90°https://uploads.tapatalk-cdn.com/202...0670843417.jpg
cazz1000 22nd January 2020 00:42
if u want a long intake,,, run a super b ,,, no better than that ,, iv,e been running a super b since 1985,, no better than a super b,,,,, on an ironhead,,when tuned right,,
dodgetrucken 22nd January 2020 00:44
Originally Posted by cazz1000 (Post 5802103)
if u want a long intake run a super b ,,, no better than that ,, iv,e been running a super b since 1985,,
I like the look of this one as well & it for a 900 so a b is a bit much I think
dodgetrucken 22nd January 2020 04:49
I don't really need more out as well that y i was think of going forward. I'm running jockey shift & when i hit 1st my skull shifter taps my breather lol. So I got 3rd...2nd...ting1st very time. It dost hurt anything it's just funny. A B would push further into my leg as well so I'm not a fan of that. https://uploads.tapatalk-cdn.com/202...73715aed2b.jpg
cazz1000 22nd January 2020 06:09
what ever,,,,,,,,,,,,,
dodgetrucken 22nd January 2020 06:15
kitabel 22nd January 2020 13:50
1. a turn tends to centrifuge gasoline droplets (heavier than air) out and deposit them on the outside of the curve... toward the rear cylinder.
2. the inertia of mixture in the tube slightly increases VE after BDC.
3. you may accidentally "find" a tuned length and get some sonic effect at a specific RPM.
