Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
0 1967 XLCH stroker project
0 Fact or Fiction - HP Claims
0 NewProject
Last Post: Rodzilla
Last Post: vagrant318
0 Cylinder Piston kits
Last Post: Dave L
0 Thinking about buying a Ironhead
Last Post: ericfreeman
5 Pre-Oil the motor somehow after long Non-running?
0 Trouble Code B1611?
Last Post: Jcolleyoh
5 Wasted spark ?
Last Post: Magneto Sportster
Last Post: whittlebeast
Last Post: kaveebee
0 More of a reintroduction
Last Post: k9unitb
8 spark plug blew out on the freeway
0 Iree's jukbox joint
0 900 heads contd..
Last Post: spacecoast
0 Battery life with total loss ignition
Last Post: Diogenes415
Last Post: lugster
0 81 ironhead gear oil large leak
0 Viking bags??
Last Post: gravydog
0 the far west burbs of Chicago
0 Diagnostic help
Last Post: BradX13
Last Post: jzink0883
forks, problems, suspension
Old 21st January 2011
Betty254's Avatar
Betty254 Betty254 is offline
Betty254 is an unknown quantity at this point
Default Forks are off
I was recently involved in an accident on my nightster (not fun). Not any major damage but I did go down on the right side. My bars took most of the abuse but now it feels like my forks are off. When I lean right it seems very loose and when I lean left it seems tight. Also when I'm riding a straight line it wants to gradually go right (as if a car/truck had a bad alignment). Is there any way I can fix the issue or do I have to bring it to the dealer?
You may all go to Hell, and I will go to Texas. -David Crockett
devilshound's Avatar
devilshound devilshound is offline
Other Motorcycle Model: bmw r75/6...gone
Other Motorcycle Year: 1976
devilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura about
Just a thought. You may want to double check the rear wheel alignment. That's been known to make 'em track funny.
-DH
Old 22nd January 2011
XLXR's Avatar
XLXR XLXR is offline
XLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond reputeXLXR has a reputation beyond repute
Loosen and retighten the front end, the forks may be twisted. There is a certain procedure to follow, but I'm too "tired" to remember what it is.
Former Ricor test rider for IAS Shocks, Intiminators and Vibranators. Works Dual Rate fork springs, fork brace, Avon Venom X tires, loosen drive belt, and set frame rails level to floor. Read the "7 Pages of Suspension" thread in the Suspension Sticky Index to learn how to fix your suspension.
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
As XLXR said, loosen the front forks. Then get out your service manual and follow the procedure for tightening 'em up and be sure to adjust the "fall away."
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
Loosen and realign the handbars also, then retighten when straight, most likely the cause of your alignment issue
just loosen the triple tree pinch bolts top and bottom to realign the triple trees, NOT ALL AT THE SAME TIME, cause the front end will drop out..
the FM is really NOT specific about the proper fall away method,
as long as the stembolt has NOT been loosened or re-torqued.. fall away shouldn't even be an issue..with the bike being lifted front wheel on, tighten it down until you have resistance. Then back off until it is smooth, swinging the front end from side to side making sure it has no resistance or no binding at all.
just double check proper alignment of the triple tree's and handlebars which most likely took the brunt of the fall causing your alignment issue..
RTFS
Ride That F'N Sportster!!
khaskins's Avatar
khaskins khaskins is offline
Sportster/Buell Model: Sportster 883L
Other Motorcycle Model: Honda CB350 Cafe Style
Other Motorcycle Year: 1970
khaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant future
If you are not familar with these procedures, you should have the work done by a professional. Having the front end setup wrong can cause some serious problems when riding at speed.
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
