Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
Last Post: Vohnsen
0 Fact or Fiction - HP Claims
0 More of a reintroduction
0 Future of the sporty?
Last Post: spitfirechopper
0 Cylinder Piston kits
Last Post: Dave L
0 Clutch Spring plate poll
Last Post: NZstu
0 Trade Chrome for Black?
0 Bars on C Riser?
0 1967 XLCH stroker project
Last Post: kaveebee
0 crack in head
Last Post: slamtry
Last Post: 45Brit
Last Post: kaveebee
0 HAMMERPerf 90" In the Works
0 Range With EFI 3.3 Gal Tank
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
Last Post: brianbbs67
0 The norse Saga's, or Pia & Tores ramblings if you like.
0 Feeling in trouble.
Last Post: sdsbassist
0 Adapters to put a 19" on rear
Last Post: Guidry
cam timing, ironhead, misfire, sportster
Old 14th May 2012
runamuk runamuk is offline
Sportster/Buell Model: XL Sporster
Sportster/Buell Year: 1979
runamuk is an unknown quantity at this point
Default Ironhead Problem!!! (cam installation)
Just changed over to a Generator from an Alternator conversion on my 1979 Ironhead sporty, but while pulling the cam cover off, I was in a hurry and a couple of cams fell out. The bike got moved around the shop a couple of times over a day or two, which kicked the crank outta the initial spot I had it. I replaced the cams (timed them), finished the gen gear and tried to start it up. It actually started however back fired like a bitch; so I realized it was 180 degrees out. I reinstalled the cams correctly and fired it again; it started however ran a little shitty, i quickly realized that the rear cylinder was not firing. However when you crack the throttle or ride it, it seems to fire the rear cylinder and it has plenty of power. The rear cylinder only seems to miss at idle! Confusing. I swapped both plugs and wires, no change. Put spark tester on rear cylinder; it's sparking at idle, at least on the tester. Pushrods are adjusted correctly too. I didn't change anything else. THe rear cylinder is definitely missing at idle tho, I pulled the plug wire off while at idle; no change in RPM and the exhaust is cold at idle.
ANYONE have any ideas??? I posted this a couple of days ago on another forum and had some replies suggesting that the cams were off so I pulled the cam cover AGAIN, they're timed correctly.
Thanks.
Old 14th May 2012
big andy's Avatar
big andy big andy is offline
Sportster/Buell Model: xlch 73
Sportster/Buell Year: sold
Sportster/Buell Model #2: 1997 1200s
big andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond repute
Dont take this the wrong way but are you sure you have the cams in the wright way one tooth out will make a huge difference. If you dont have a fsm check in the stickys for a picture of the correct cam timming .
1997 1200s 1250 Hammer performance kit . Hammer performance billet inlet manifold .Hammer performance billet pushrod tube holders. energy one extra plate clutch kit . bronze oil pump drive gear upgrade
Old 14th May 2012
I do have a Factory Service Manual and the cams were timed per the manual, also I did check the stickys section on this site (which was great) and it confirmed that I had them timed correctly too.
Also, if the cams were off; I can't understand why it runs strong under load. I would think that having the cams out of sync would cause a problem at any RPM/Load, etc.
Old 15th May 2012
big andy's Avatar
What ignition system you using going by what you say the problem is not firing at idle but off idle it runs strong.F you are using points check the gap on both the small and large lobe to bigger difference between them will do what its doing Plus if you are running points removing the cams will sent the timming out of wack . If you are using electronic ignition recheck the timming as it probably will be off . Even if you havent touched the backing plate on the points plate or electronic backing plate the timming must be rechecked .But if its points my guess is the points not right hope this helps All the best andy
Old 15th May 2012
Thanks for the help, Andy. I figured it out; when I put the pushrods back in I had the front cams on the heel of the lobes, adjusted them just fine. Then my buddy came by and we started BS'n, and drinking. Basically I lost track of where I was in the process of adj the pushrods. I forgot to move the rear cams to the heels, so I basically had the rear pushrods out of adjustment. Doi! That's why I love ironheads; you can screw em up and they still run. That would of probably destroyed an Evo!
Old 15th May 2012
big andy's Avatar
Glad you got it runnin good .Now go put some miles on her
