0 2016 48 Hesitating
Last Post: Screw Loose Dan
0 Ei
0 24633-77 Breather assembly
Last Post: Dave L
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
Last Post: Larry May
0 Is this a float height issue?
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New Member in Green Bay, Wisconsin
7 New Guy here, Central Coast CA
0 New England 2018
Old 21st July 2012
EdT EdT is offline
Sportster/Buell Year: 1972
EdT is an unknown quantity at this point
Default Need help finding brake line
trying to find a front brake line for my 1974 XLH. Stock front end. Everywhere I look seem to be out of stock or discontinued. Any help finding one would be greatly appreciated. Thanks in advance.
Old 21st July 2012
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
Check here: http://www.jpcycles.com/product/242-843
If you need it now check out a hose shop.
Old 21st July 2012
EdT EdT is offline
I looked at JP already. The link takes you to the out of stock line. Thanks for the help
Old 21st July 2012
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
If your just wanting a brake line and not an OEM line you should be able to get exactly what you want from Magnum Shielding as long as you know the length. Start at this page and select a length: http://magnumshielding.com/store/uni...brake_line.php
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 22nd July 2012
EdT EdT is offline
thanks but Mangnum Shield doesn't t work because they only sell cables with the Banjo fittings. The stock XLH Cable is a flair fitting into a pipe thread.
Old 22nd July 2012
EdT EdT is offline
Think I found one. If anyone else needs I got it at http://www.phatperformanceparts.com/...DKITS&CartID=1
