Last Post: Dave L
0 Stock vs. Modified
Last Post: blindfredy
0 rethreadable?
Last Post: senseigreen
Last Post: mct496
Last Post: conv90
Last Post: Jowniofownio
Last Post: brianbbs67
0 Intro from New England
0 Diagnostic help
Last Post: jzink0883
8 Crankshaft Failure
Last Post: spitfirechopper
0 Head gaskets.
Last Post: Fridge
0 HAMMERPerf 90" In the Works
Last Post: MatHormell
Last Post: Ben221
0 Need map, switching to power vision
0 first harley- help!!
Last Post: cantolina
0 oil cooler or not?
0 Engine dies when choke off
Last Post: shovithead
Old 29th March 2007
EZStroke's Avatar
EZStroke EZStroke is offline
Sportster/Buell Model: 1200L Vivid Black
EZStroke is on a distinguished roadEZStroke is on a distinguished road
Default Sensitive Throttle
My '07 1200L has a sensitive throttle to the point where it will 'slip' when I hit the right turn signal just by the movement on the grip. I tried to adjust the thumb knob on the bar but with the amount of play in going from idle to starting out, I find that this is not the answer.
Anyone had the problem or know of an adjustment on the EFI setup?
Andy
Semper Fi!
'07 1200L Vivid Black Stage I
Old 29th March 2007
obiwan's Avatar
obiwan obiwan is offline
Sportster/Buell Model: Sold
Other Motorcycle Model: Kawasaki Nomad
Other Motorcycle Year: 2007
obiwan has a spectacular aura aboutobiwan has a spectacular aura aboutobiwan has a spectacular aura aboutobiwan has a spectacular aura aboutobiwan has a spectacular aura aboutobiwan has a spectacular aura aboutobiwan has a spectacular aura aboutobiwan has a spectacular aura about
Seems to be standard fare on the 07's. Mine was the same and the throttle friction lock does little to dampen it. I think you'll also find the twitchy throttle is a consequence of the extreme lean settings of a stock bike. When I replaced the mufflers with slipons, opened up the A/C and added a fueler, which fixed the overly lean running, rideability improved out of sight and the twitchy throttle all but disappeared.
It took some tweaking to get the fueler mixture right, but now that I have it's like riding a completely different machine. There are a few options on the EFI to achieve stage 1 and most opt for a factory remap.
Unfortunately, until you fix the lean mix, you're going to have to perservere with that touchy right hand.
obiwan
XL50 #1112 Vivid Black (sold Nov. 2007)
Fi2000r-O2; SE Heavy Breather Pro; V&H Straightshots; Progressive Suspension; Fwd Controls; Mustang Vintage Solo; Obligatory Bling
Old 29th March 2007
EZStroke's Avatar
Default Throttle
Have to watch it close as the front wheel comes off the ground when it slips. I didn't have the problem on the spring loaded carb '04.
I don't do wheelies!
