Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Frame Mount EVO Sportster Talk (1986-2003 models)
5 Who wants to guess what's trying to kill me on my bike?
Last Post: XLXR
0 Is this a float height issue?
Last Post: brianbbs67
Last Post: barefoot
0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
5 Metal Gaskets or RTV for top end?
Last Post: groovemeisterus
Last Post: rwharris
0 5/6/18 - Keene Spring Motorcycle Swap Meet
Last Post: tvon
0 New guy, first H-D, '65 XLCH, today......
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
0 Crankcase Interchangeability
Last Post: x1_guy
Old 11th April 2007
Gone Gone is offline
Angry points cover
Hey to all sportster guys and gals
studid question
how do you take the points cover of a 94 1200
Want to replace it just because it looks bad, but it looks like it is pop riveted on there?
Old 11th April 2007
a45junkie's Avatar
a45junkie a45junkie is offline
Master Bike Builder
Sportster/Buell Model: XLH883/1200
Sportster/Buell Year: 96
Other Motorcycle Model: CX500
Other Motorcycle Year: 84
a45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nicea45junkie is just really nice
your right they are pop rivets, but special sealed ones.
drill off the heads remove the cover and the plate under it popout the tails from the plate and get new revets for the new cover.
or use self tapping screws to hold it on like i did
96 XLH883/1200
BUB Reinhart 2-1 exaust fitted with supertrapp muffler 24 disks
big sucker stage one
progressive suspension
Old 11th April 2007
Scooter_Trash's Avatar
Scooter_Trash Scooter_Trash is offline
Sportster/Buell Model: Rat Bastard
Other Motorcycle Model: Honda CL175-Rot'n Bastard
Other Motorcycle Year: 1970
Scooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really niceScooter_Trash is just really nice
Drill the rivets out then replace with rivets again (good) or self tapping screws (gooder).
Old 11th April 2007
Jim
cool man, thanks for letting me know
want to put something on there with some chrome ya know, the stock one looks crappy
Old 11th April 2007
fire medic
cool,
thanks to you 2 man
Old 16th May 2007
br_xl's Avatar
br_xl br_xl is offline
br_xl has disabled reputation
What? Ain't no points on a '94!
Old 22nd May 2007
Steve3888's Avatar
Steve3888 Steve3888 is offline
Sportster/Buell Model: XL833R
Steve3888 is on a distinguished roadSteve3888 is on a distinguished road
Still called a points cover though.
Old 23rd May 2007
br_xl's Avatar
Called timer cover in my manual. But who cares, right?
As far as special HD rivets, give me a break. That's the whole purpose of pop rivets, as they're called in the manual, so you don't need access to the other side. They wouldn't use them on aircraft if pieces fell out behind them. They are soft aluminum with a steel core (mandrel). The mandrel is pulled with a rivet gun, the back side of the aluminum mushrooms out, and when enough tension is reached on the rivet gun side, of the mandrel pops off. This is plenty water tight as long as the steel mandrel stays put, which its designed to do. Even in an open-end pop rivet, the head of the mandrel stays wedged in the mushroomed aluminum.
Old 23rd May 2007
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
________________________________________
That's the whole point of using the special H-D rivets so they DON'T have the mandrel pop off!
That's like throwing lose metal in there. NOT a smart idea!
Tolerances are also such that when the rivet is drawn tight, the correct thickness of the parts will pull the cover tight. It doesn't take much to let water in.
Notice how the service manual states the warning in HEAVY print.
They did that for a reason. To warn you when R&R on the timing cover!
Two new rivets will run less than a buck. They were cheap enough, I bought a 1/2 dozen to have in case I wanted to open up the timing cover again. I think it was still close to a buck for 6 rivets. Very cheap!
Using the right parts is the right thing to do!
Don't be cheap. It's a many thousand dollar machine and saving pennies on the wrong parts is dumb.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Old 22nd May 2007
wrongpaw wrongpaw is offline
Knuckle Draggin' Mechanic
Sportster/Buell Model: XL 1250 Red-taxes paid
Sportster/Buell Model #2: XL 1250 Black-taxes paid
wrongpaw has disabled reputation
The holes in the inner cover that the rivets fit are the perfect
size for tapping for 10-32 NF threads. Then use 10-32 X 1/2 "
binding head S.S. screws to attach the outer "5" cover.
Regards,
Mike (aka wrongpaw)
2001 XL883/1250 Red (taxes paid and then some...)
2001 XL883/1250 Black (Just like the red one)
