Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
0 Need advice (Falters When Turning Corners)
0 Spokes or Mags
0 -75 ironhead, My first HD
Last Post: brianbbs67
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
0 Lowboy frame conversion
Last Post: barefoot
0 How do you upshift?
0 Oil Hose replacement help.
Last Post: Jollly Rogers
0 Stage 1 results
Last Post: 09Nightsterrider
0 Want to buy: solo saddle bracket and hardware
Last Post: Dsantizo2
0 Forty-Eight Special and Iron 1200 Sportsters announced today
Last Post: Jheitt
0 Solar battery charging
Old 25th May 2005
jimmyheadgear's Avatar
jimmyheadgear jimmyheadgear is offline
Other Motorcycle Model: Triumph Speed Triple 1050
Other Motorcycle Year: 08
jimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished roadjimmyheadgear is on a distinguished road
Arrow Some belt guard help, please
I'm going to remove the upper and lower belt guards. It looks like I'll have to loosen or remove the lower rear shock bolt to get the nut for the guard off.
Is this correct?
If so, how hard is it to loosen the bolt? I'm low on tools right now and don't want to open a new can of worms.
[COLOR=Sienna][SIZE=3][FONT=Arial Black][COLOR=Black]Pete
[/COLOR][/FONT][/SIZE][COLOR=Black][FONT=Arial][SIZE=2][IMG]http://i19.photobucket.com/albums/b189/jimmyheadgear/croppedDSC_2160.jpg[/IMG][SIZE=4][B]
It's a shame that stupidity isn't painful!
[/B][/SIZE]
[/SIZE][/FONT] [/COLOR][/COLOR]
Old 25th May 2005
SkippyRay's Avatar
SkippyRay SkippyRay is offline
Sportster/Buell Model: 883r /1200 upgrade
Sportster/Buell Year: 02
SkippyRay is an unknown quantity at this point
Not hard and yes you will have to take it off, unless you want to cut it off.
[FONT=Comic Sans MS]Why do I walk backwards you may ask....
Because [COLOR=Red]Karma[/COLOR] travles full circle to all....
And I want to see that Bitch coming!
:gun
[/FONT]
Old 25th May 2005
Skippy
Do you mean cutting right at the tab and grinding down the end to hide it?
Thanks
Old 25th May 2005
Moved On Moved On is offline
Moved On is an unknown quantity at this point
Don't cut it!!! Just take the nut off the back of the bolt. I almost think you don't even have to pull the bolt, can't remember for sure. I took my belt guard off without the use of a lift.
Gazza
Old 25th May 2005
Grizzly's Avatar
Grizzly Grizzly is offline
Other Motorcycle Model: FXDWGI
Grizzly is on a distinguished roadGrizzly is on a distinguished roadGrizzly is on a distinguished road
I swapped mine out for chrome ones and did not remove the shock???
Old 25th May 2005
Thanks guys! I didn't think it would be that easy.
Old 25th May 2005
DM-SC's Avatar
DM-SC DM-SC is offline
Sportster/Buell Model: XL 883
Other Motorcycle Model: Heritage Classic
DM-SC is an unknown quantity at this point
Though it's not hard, I'm sure the lower shock bolt has to come out. Just remove the nut and the bolt should slide fairly easily...though it may require a bit of convincing.
Here's a pic of the Belt Guard . You can see that the bolt goes through the rear mounting tab.
Some minds are like concrete..thoroughly mixed up and permanently set!
2004 Heritage Classic - Ness Big Sucker, V&H Longshots, PCIIIUSB
Former Sporty Pilot...Now riding a "Road Sofa"
Old 25th May 2005
Grizzly's Avatar
I just backed it out eough to get the gaurd of, I never pulle dthe bolt out. It was very easy.
Old 25th May 2005
DM-SC's Avatar
When I said "come out", I meant it has to come out enough so the lower part of the shock is loose from the swingarm. You can leave the bolt in the lower shock eye...
Old 27th May 2005
exit143's Avatar
exit143 exit143 is offline
exit143 is an unknown quantity at this point
I just did mine. All you have to do is remove the nut in the back. You don't have ot remove the bolt at all - very easy. The lower guard on hte other hand...Three bolts (7/16 I think) the two closest to th rear are easily accessible with a socket and an extention the bolt closest to the front is in a tight space so you'll need an open end wrench (offset would be better but if you don't have on a standard will do but take longer). You don't have to remove the bolts, just lossen them and the lower guard will slide off it have "key hole" openeings. You will have ot remove bolts to put the new one one but it's easier to get that front one without the guard on.
