5 '77 ironhead fork neck cup conversion internal steering stop
Last Post: Slojoe55
0 2 into 1 exhaust build
5 Why Are You Still Married?
Last Post: oupa
0 Spectro STL 75W140
0 How do you upshift?
0 Do people notice your bike?
0 Hoo rah for Missouri.
0 03 sportster front muffler Stud nut Thread size?
Last Post: gravydog
Last Post: ReddTigger
0 Cv carb jet question
0 900 dual carb front head
0 exhaust or cams?
Last Post: wrkdWS6
0 Oil Analysis?
Last Post: Bwf347
Last Post: oupa
Last Post: Four Speed
Last Post: spacecoast
Last Post: 83XLX
0 The Multi-tool thread
Last Post: gpydeski
0 S.Y.B. Next to a waterfall.....
Last Post: Lone Rider
0 new heads
Last Post: gpydeski
0 Runs rough on highway.
Old 11th August 2009
MonkeyMadness's Avatar
MonkeyMadness MonkeyMadness is offline
Sportster/Buell Model: XLCR
Sportster/Buell Model #2: Sold 883R / 1425
MonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the roughMonkeyMadness is a jewel in the rough
Default Help! I can't get my Pulley Nut Off! Ahhhh!
Ok so I've just started my tear down of my 03 sporty...
I'm going to 88ci and I need to strip the case to have it bored...
Well I've got the top end off, cams out, starter out.. all the crap on top
now looking to pull the tranny... and I'm stuck....ugh..
I can't seem to get the pulley off...
Is there a trick to it?
My book says it has a left hand nut... ok clockwise to remove...
but I can't get this thing to budge....ugh
HELP...
Where's my pants? Tell your mom to stop calling me, I'm not your Dad!
rabidchimp rabidchimp is offline
Sportster/Buell Year: 97
rabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enough
You're right....lefty-tighty. I used an impact gun.
-Aaron
Stairman for President 2012, 2016, 2020 etc.
rfranz1952's Avatar
rfranz1952 rfranz1952 is offline
Sportster/Buell Model #2: XLX
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Yamaha Vino 125
rfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nice
They can also be tighter than ?&&^$%!
You might need a breaker bar and cheater pipe. An air impact wrench helps too.
2005 XL 1200 Custom; NRHS 1250 Conversion, 10.5 - 1; Stage 2 Heads; SE 536 Cams; Jim's Hydrosolid lifters; NRHS adjustable pushrods; S&S Roller Rockers; Crankshaft by Darkhorse Crankworks; HurricaneFlow A/F; Hurricane Oil Filter; Mikuni HSR-42; S&S Intelligent Spark Technology Ignition; RB Racing LSR exhaust; Front and Rear Progressive Suspension; Oversize front tire; Superbrace Fork Brace; Speedway Microtach, lots of other bits and pieces.
THE $16,000 Sportster!
seajay's Avatar
seajay seajay is online now
Sportster/Buell Year: 04
Yep. It took a lugnut impact driver to get mine off.
04/07 1275 BFH heads .590 cams S&S 1.725 rockers TC88A HSR-45 S&S ac LSR 2-1
Originally Posted by rabidchimp View Post
Counter clockwise to remove. Its the clutch basket nut thats righty-loosy.
-Aaron
Ummm
I have the 2003 H-D service manual P/N 99484-03
Chapter 6 Drive/transmission
Page 6-18 Figure 6-17 Transmission sprocket
"Note : Transmission sprocket nut has left-hand threads. Turn nut clockwise to loosen and remove from main drive gear shaft."
Now I'm really confused....
I'm sorry. I thought I read "primary" nut......on the crank shaft. The clutch basket and pulley on the other side of the trans ARE right-hand threads. Thanks for chiming in guys. I've edited my post.
-Aaron
ol38y's Avatar
ol38y ol38y is offline
Sportster/Buell Model: 1250
Sportster/Buell Model #2: 1350 S+S
Sportster/Buell Year #2: 1995
Other Motorcycle Model: Screaming Eagle Ultra
ol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud ofol38y has much to be proud of
The belt pulley is left hand thread. You'll prolly need an impact cuz there's red loctite there...
When in doubt, gas it...
Ol' Chief Larry of the Dirty Ducks MC
Ok call me chincy, cheap, or just plan crazy But I can't see paying $35-40 for
a impact socket I'm only going to use twice!
But I'll use a $1.5mil laser table sitting on my shop floor Hell ya!
Jumped on the computer drew it up, and cut the damn thing!
Put on my Welding helmet, and tigged up my own socket! FTW
Heat treat it with a torch and a can of oil...
Going home at 4:30 to show that nut who's boss!
ol38y's Avatar
LOL, well other then the Pomona Swap Meet and a couple F1 races your schedule looks pretty free... So, why not make a socket...
Oh yes... busy month!
