0 first harley- help!!
Last Post: rickthrash99
0 2nd year in a row paid member
Last Post: brianbbs67
5 Is anyone with an early sportster running a 38 mm Mikuni?
Last Post: lo-rider
0 project 74 sporty
Last Post: CaptEvo
Last Post: cotton1
0 Mikuni HSR42 Initial setup..
Last Post: The Crusher
0 Engine dies when choke off
0 Feeling in trouble.
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 newby from Australia
Last Post: philipml
0 Cylinder Piston kits
Last Post: chevelle
Last Post: Don Biter
Last Post: blindfredy
0 Future of the sporty?
Last Post: felis
0 fuel in the oil tank
Last Post: Sadsack
Last Post: Ben221
5 Am I looking for Trouble ?
8 spark plug blew out on the freeway
0 Nighster seat on Iron
Last Post: BSA Bob
0 EFI manifold / throttle body question
Last Post: Screw Loose Dan
0 Well, damn. Cracked bracket.
5 Transmission HELP!
0 Tourmaster Transition 5 jacket:
dtw757 (64), XLH75Rider (63), JRLang13 (56), Shaerona (54), christophe (51), collectovince (50), buckethead (40), Hang_Em_High (38)
Old 3rd November 2009
ericfreeman's Avatar
Sportster/Buell Year #2: 1977
Other Motorcycle Year: 1979
ericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to beholdericfreeman is a splendid one to behold
I'd install the V-Twin ratchet plate. I did this on my '78 when I fitted the kicker kit and so far there have been no problems with the teeth engaging: never any slippage when kicking. Although to be honest, I almost never kick start the bike since the electric is so much more convenient.
Eric
Old 4th November 2009
rokdoctor's Avatar
rokdoctor rokdoctor is offline
Sportster/Buell Model: Hardtail
Sportster/Buell Year: 1970
rokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the roughrokdoctor is a jewel in the rough
It's on and moves smoothly!!!
Thanks for all the help guys - especially Eric, your input is invaluable.
Heres a pic for the fun of it.
Congratulations on your kicker install success!! Always happy to help a fellow Ironhead enthusiast.
Eric
Old 3rd February 2010
Joey-D's Avatar
Joey-D Joey-D is offline
Sportster/Buell Model: 1200
Joey-D is an unknown quantity at this point
What is the purpose of the thrust washer? I am having the same problem with my install. Damaged the original bushing when removing it, so I can really try putting it back in. Everything seem too tight when torqued down. I had the shim the large kick gear and now its too tight. Will it loosen or should I torque it less since it has the lock on it? My V-Twin kit didn't come with any kind of directions at all. Trying to install this with my FSM. Got it figured out now, but a little guideness would have been nice. Just kinda stumbled on the fact the starter ratchet actually gets riveted to the clutch shell.
1976 Ironhead with 71 XLCH Motor
1997 Police FHLPi
2001 Heritage Softail Springer FLSTSi
Joey-D's Avatar
I am having a hell of a time lining out the ratcheting plate, drilling holes, riveting it and keeping it in line. Is there any reason I can weld the ratchet plate to the clutch shell? I got the tightness fixed from above, had to use a different shim.
Old 4th February 2010
Joey-D's Avatar
I have to line the ratchet gear and clutch shell up, drill holes, rivet it and keep it all lined up. Is there any reason I can weld the ratchet plate to the shell?
I fixed the tightness by shimming it some more.
No real reason you can't weld the ratchet plate onto the clutch basket. There's a special tool that holds all the parts in alignment while you drill and rivet. Rivets also make it easier to replace.
However, I recently discovered my V-Twin rivets had loosened up a bit allowing some slop in the ratchet plate so I welded the plate in 4 places. Each weld is about an inch in length. I ground the welds flush to the ratchet plate to ensure no interference anywhere. If I ever need to replace the ratchet plate I'll just grind off the short welds.
Eric
Joey-D's Avatar
Fantastic. I am really learning a lot doing this kicker install. I have the FSM and ordered the V-Twin kicker kit. Blows my mind the kit didn't come with an instructions at all. Ended up going back and forth between the basic primary break down and the kickstart break down to see what I needed to replace. Got it figured out now. Looking back at it, it was quite simple, but if you have never been inside a primary or ever owned a kickstart bike it makes it quite difficult. I am man enough to admit this one, for instance I didn't know the kicker shaft went behind the transmission in plugged holes. I literally thought it replaced the transmission shaft. Pulled the transmission and then scratched my head. Well, atleast now I know my tranny gears are in good shape. I have taken a bunch of pictures and will upload them when I finish installing the kicker and verify I did it right. No need for the blind to lead the blind.
