0 1982 rubber oil hoses
Last Post: Gravitas
Last Post: Bikeaholic
Last Post: Animosity
0 1975 Sportster
Last Post: Porkchop9
Last Post: SophieWillow
Last Post: 1Scooter
Last Post: jeffro57
0 Indicators not flashing
Last Post: steve-o-
0 1975 Sportster
Last Post: bplinson
5 1975 Sportster
Last Post: Whitewalls
0 Carb ???
Last Post: jibber
0 Gear and brake linkage
Last Post: 93trident
0 1965 XLRTT article
  #111
Old 14th March 2011
Crazyspeed's Avatar
Crazyspeed Crazyspeed is offline
Sportster/Buell Model: XLS
Sportster/Buell Year: 1979
Sportster/Buell Model #2: Moto Guzzi Griso
Other Motorcycle Model: Moto Guzzi V7 sport
Other Motorcycle Year: '73
Crazyspeed is on a distinguished roadCrazyspeed is on a distinguished roadCrazyspeed is on a distinguished roadCrazyspeed is on a distinguished roadCrazyspeed is on a distinguished road
Originally Posted by zipdog View Post
Hell no...I want to BRAG about it. Owned my first Harley (shovel) at 50 and now my first Ironhead. Way to go, IronMick...I'm 1 1/2 years behind you.
Ok...I'm giving you a little poke....I myself go back a little...graduated from high school in 1964
CRAZYSPEED
Old 3rd April 2011
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
Default Race lapping tools
Inexpensive industrial expandable lapping arbors that could be used to lap rod races, main bearing races, tranny mainshaft output race etc are here:
(brass barrel)
http://www.acrolaps.com/index_009.htm
http://www.acrolaps.com/index.htm
And here:
(Hardened steel barrel)
http://www.americanlap.com/Expanding%20Mandrels.htm
You would need a lathe to make up the aligning extensions for the tranny bearing and main bearing lapping, but should work straight up for con rod races.
Old 11th April 2011
1979XLH 1979XLH is offline
1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough1979XLH is a jewel in the rough
clutch spring install tool...
also for anyone putting on a primary cover. the clutch ramp and balls can be held using a small pair of needle nose vise grips.. works amazing
Old 16th April 2011
Wooley Wooley is offline
Wooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to beholdWooley is a splendid one to behold
Either I missed this thread altogether or forgot about it. Great stuff in here.
"Every solution creates another problem"
"Go ahead and jump ... and hope the chute opens"
"For the sake of being a gentleman I'm kidding, in reality though I'm not."
Old 27th May 2011
Big_e78 Big_e78 is offline
Sportster/Buell Year: 1968
Big_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enoughBig_e78 will become famous soon enough
Originally Posted by Big_e78 View Post
This bearing separator and gear puller set has worked for everthing I've come across so far, though I haven't pulled this particular one. I even rigged it up to press my flywheels out of the case.
http://www.harborfreight.com/14-piec...set-30305.html
I just confirmed this by using this puller. Came off easy. Now putting a new one on may be harder. I only have a small press...
Old 27th May 2011
rivethog's Avatar
rivethog rivethog is offline
Sportster/Buell Year: '78
Sportster/Buell Model #2: 883 XLH
Sportster/Buell Year #2: 1993
Other Motorcycle Model: 93" Shovel/Pan
Other Motorcycle Year: 1967
rivethog has disabled reputation
Originally Posted by fergerburger View Post
The race butts up to the wheel.
I've never seen a Sporty sprocket shaft that didn't have a lip/bearing seat on it. If that lip contacts the flywheel before the shaft taper seats in the flywheel, you've got problems.
ACE Hardware gr. 8 bolts Krylon & Rustoleum "premium" paint JT-6 waterproof grease, Emgo oil filter Loctite blue red & green AutoZone headlight bulb soxxet genuine Aftermarket rear fender generic countershaft sproxxet Radio Shaxx 16ga & 14ga wire forks off of a 180mph drag bike Swallow 4.60H18 rear tire 3.50 x 19 Shanghai front
Old 2nd July 2011
piniongear's Avatar
piniongear piniongear is offline
Sportster/Buell Year: 1971
Other Motorcycle Model: FXDL
piniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to allpiniongear is a name known to all
Originally Posted by 71sportyratfink View Post
Is there a way to install the pinion gear without buying the 96830-51 tool or should I take it to a shop ?
There is a tool used to install the gear.
The tool has 5/16-24 left hand threads which screw into your crank spindle.
You can press this gear on if you do not have the tool, but using the tool is the preferred way of doing it.
I do not have the factory tool myself but made my own as pictured here..........
pg
Rolling down the highway on two wheels since 1957...
Owner Red/White 1971 XLCH & 2003 FXDL-Silver over Black
Old 11th August 2011
saddlebagrail saddlebagrail is offline
Sportster/Buell Model: FLH Electra Glide 67/82
Sportster/Buell Year: 77
saddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to beholdsaddlebagrail is a splendid one to behold
Default other homemade tools
I have seen some nice homemade tool in this thread,here are some that I made over the year, for those who are doing flywheel works,Ray
My first knife edge stand for balancing flywheels
My last roller bearings balancing stand for flywheels,this is the one I am actually using.
Set of bobweights and shaft for balancing purposes(static)
A dynamic balancing bobweight sets(dynamic)
Default connecting rods weighting tools
this kit is made to balance rotating and reciprocating weight for engine balancing
weight that I need to take off when balancing either Big End or Small End
Old 13th August 2011
Default holding the flywheel when pressing Timkens
Press the Timkens with another homemade tool
