Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Transmission, Clutch, Primary & Secondary Drive
0 Diagnostic help
Last Post: BradX13
Last Post: jordan1200
0 Stock 883 cold blooded
Last Post: Diogenes415
7 Long Road Trip advice
Last Post: gunwish
5 Did you go back to an OEM plungers seat? Like it?
0 Leaks
Last Post: Steven2142
0 Value of a Boattail?
0 z bars
Last Post: 201648Rider
Last Post: 72 Ironhead XLH
2 Humble pie
Last Post: Sprtstr1200s
0 Spring Seat Brackets?
Last Post: RussW
Last Post: gravydog
0 New to Harley
0 79 ironhead
0 Back in Sporty Land
0 1967 XLCH stroker project
0 Head gaskets.
Last Post: 883openpipes
0 1200 heads in stock 883 bottom?
0 99 1200s clutch drag
Last Post: NZstu
Last Post: paulc
0 79-83 dual disc fork spring length
Last Post: Reverend G
Old 30th August 2011
beerlover beerlover is offline
Sportster/Buell Year: 1981
beerlover is an unknown quantity at this point
Default chain condition check
How do you know when it's time to change your drive chain? The sprocket teeth look good and it isn't at the limit of the adjuster yet, but it is definitely tighter on one spot and looser on another when you rotate the rear tire. It seems like this loose/tight condition is causing the bike to kind of chug along a little bit at around 30-40 mph.
Sorry - wrong forum. This is on a 81 XLH...
