0 Another use for your Iornhead engine.
Last Post: jammantoo
0 What is this?? 07 efi 1200 weird box
0 The norse Saga's, or Pia & Tores ramblings if you like.
Last Post: norseXL
0 My Sportster basket case has arrived!
Last Post: VH5150
0 WTF Happened
0 Cylinder Piston kits
0 Diagnostic help
0 Tool Roll Help
Last Post: hexnut
Last Post: hexnut
0 Crusty Curmudgeon’s Sportster Dictionary
Last Post: Matt397
Last Post: Coz
0 An iron head on Devil's Island
Last Post: spacecoast
0 84-90 lifter block bolt- what sort is it?
0 Throttle Cable Install Problem
Last Post: Turbo Sporty 48
Last Post: jordan1200
0 05 and 73
0 Brake light stays on
0 S&S Stealth
Last Post: lucifer_mr2
0 Front brake won't bleed 1989 sportster
0 Not charging issue!
Last Post: tvon
0 HAMMERPerf 90" In the Works
0 Iree's jukbox joint
Last Post: Sadsack
0 If you have European tilt
Last Post: brianbbs67
Old 10th November 2011
DK Custom's Avatar
Sportster/Buell Model: 883L
Default XLForum Members Only - $20 Savings on Flying Knuckles
XLForum Members
$20 Savings
Today thru November 16
Flying Knuckle Foot Pegs
Use Coupon Code XLF-Knuckles at Checkout for $20 off
Check em out HERE.
chardhin's Avatar
chardhin chardhin is offline
Sportster/Buell Model: xl 883c<1212
Other Motorcycle Model: RoadKing Classic
Other Motorcycle Year: 2010
chardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond reputechardhin has a reputation beyond repute
You all should make those with quick release pins.
I find it hard to believe that "everybody" was Kung Fu fighting.
DK Custom's Avatar
We do!
Look Here.
darkdesign's Avatar
darkdesign darkdesign is offline
Sportster/Buell Model: xl883c
darkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to beholddarkdesign is a splendid one to behold
I'd be a little worried about grip with wet boot soles. A few s/steel grub screws would help, and look pretty mean too
bitpusher bitpusher is offline
outside the box racing
Sportster/Buell Model: Turbo 1350 XLSR
Sportster/Buell Year: 99
Sportster/Buell Model #2: Turbo 1350 XLDS project
Sportster/Buell Year #2: 2000
Other Motorcycle Model: 883->1330 dragster
Other Motorcycle Year: 1991
bitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant futurebitpusher has a brilliant future
easy access works both ways, especially when you are not around AND have interesting bling. just sayin....
the nucks look a little big to be usable, i.e. fit on a normal hand?
"Only those who will risk going too far can possibly find out how far one can go." - T. S. Eliot
TGB #8
I do like these
how bout a discount on them?
DK Custom's Avatar
We tested many different surface coatings and ended up using HD Wrinkle Black..they grip well dry or wet.
Not as tight as our trap pegs and traction pin pegs. But I have used these knuckle pegs for thousands of miles in the rain and never had my boots slip on them.
I bet they would look really good with some brass screws in them though!
DK Custom's Avatar
Yeah, if anyone saw you remove them by just pushing the pin out, then they would know.
They are standard size knuckles - finger holes are 15/16" in diameter.
We have only found one country we cannot ship to...Australia. Even though they are declared as foot pegs, Australia customs will NOT clear them.
DK Custom's Avatar
I do like these
PM sent.
darkdesign's Avatar
yeah, typical. We can't even go to Thailand and come home with a collection of cool toys. Any switch, flick, or butterfly knives don't make it thru the airport.
