Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Tires, Wheels, and Brakes
0 1968 XLCH Oil Leak
0 Sportster or Street Bob
Last Post: Bone
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 no rear brake light
0 2016 48 Hesitating
Last Post: 201648Rider
0 antique plates and insurance
Last Post: 60weight
0 New member in MD
Last Post: xraytoken
0 Help me with gas cap...
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Kicker shaft recommendations
0 Cad Plating
Last Post: conv90
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
Old 20th September 2009
Phelan's Avatar
Phelan Phelan is offline
Sportster/Buell Model: EBR 1190 SX
Phelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud ofPhelan has much to be proud of
Default Buell Wheel Bearing Information
Just thought this would come in handy for anyone out there looking to replace their wheel bearings soon or working on a wheel swap like me. The numbers in perintheses are in milimeters- Outside Diameter (OD), Inside Diameter (ID), and Width (W).
Castalloy Wheels - NSK bearings
Front wheel - 6204-2RS (47 OD, 20 ID, 14 W)
Rear wheel
Right side - 6205-2RS (52 OD, 25 ID, 15 W)
Left side - 62205-2RS (52 OD, 25 ID, 18 W)
PM (Chrome) Wheels - NSK bearings
Rear Wheel - 6205-2RS (52 OD, 25 ID, 15 W)
XB Wheels - FAG bearings (IIRC)
Front wheel 6005.2RSR (47 OD, 25 ID, 12 W)
Rear wheel 6006.2RSR (55 OD, 30 ID, 13 W)
On a side note, you can use the part numbers and go to your local BEARING SUPPLY STORE and find brand alternatives if you desire, but remember, not all bearings are created equally. Also make sure to use the proper torque specs tightening down your axles so that you don't overtighten them and damage the bearings.
On a side note, I used Koyo 6204-2R's in my XB front wheel conversion. The bearings are the same dimensions as the NSK tuber bearings, but were $11/pr.
Love is the never-ending act of forgiveness - Peter Ustinov
Phaedrus's Avatar
Phaedrus Phaedrus is offline
The first time I have an issue with my new and improved 09 bearings, I'm doing the 2010 wheel and larger bearing swap
Old 5th October 2011
devilshound's Avatar
devilshound devilshound is offline
Other Motorcycle Model: bmw r75/6...gone
Other Motorcycle Year: 1976
devilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura about
I know I'm digging up a near dead thread here, but I'm hoping one of you could expound a bit on the industy part numbering system. I've found a bearing number 2205 with the geometry of the 62205 & wondered if it'd work. The load & RPM rates look to be ok I wasn't sure if I was missing something.
Thanks,
-DH
Old 4th December 2011
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
Those 62205's are pricy huh? I don't have a specific answer to your question but I have been buying bearings at a local bearing supply house for decades and their prices have always been dirt cheap with one exception, that 62205.
Best price I found was Amazon believe it or not. If memory serves, I even found ceramic bearings too though I didn't get those.
-DH
Old 9th December 2012
grbrown's Avatar
grbrown grbrown is offline
Sportster/Buell Model: XB12R
Sportster/Buell Year #2: 2011
grbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nicegrbrown is just really nice
I use my local Yamaha dealer to supply and fit my tyres, but was shocked when they told me the bearings in both my Buell's wheels were shot last tyre change, but they had replacements in stock! So these bearings are widely used on other brands and should be easy to find.
Graham.
Old 13th June 2015
Phelan's Avatar
Default Old thread, new info
I can't add to the OP, but the 2010 Buell rear wheel uses 3 of the following bearings
6206-2RS, 62 x 30 x 16 mm with double seals
