0 1974 Ironhead
Last Post: paulc
0 24633-77 Breather assembly
0 Ei
Last Post: Serious Blac
0 Dytch/Axtel Cylinder Identification?
0 New from Utah
0 Post season carnage
0 De-lowing a Superlow with Progressive Monotubes?
Last Post: FuriousGeorg
0 Exhaust Clamp Fitting
Last Post: Yochstein
0 5spd Evo Sportster engine in '85 frame
Last Post: norseXL
0 Rubber mount Oil tank Vent line Routing
0 Need help on bolt size - 92 XL1200, mid pegs
Last Post: r4fthrs
0 Reflectors...Yeah, or Neh
Last Post: 60weight
0 1250 Conversion troubles
fuel, inside, seal, tank, weld
Old 26th March 2012
cminsel83 cminsel83 is offline
Sportster/Buell Model: xlc
cminsel83 is an unknown quantity at this point
Default Do I need to reseal my tank?
I recently welded a plate of steal to the bottom of a forty eight tank to cover the fuel pump hole and covert the tank to work with a carbed 05 XLC.
Do I need to reseal the inside of the tank? It was sealed from the factory, but I'm afraid the welding could have damaged it, or the new plate could rust from the inside. I put 3 coats of rustoleum on the weld which is located on the bottom of the tank.
I called a radiator shop and they quoted me $180 to clean and seal the inside. Seems a little pricey.
Any advice would be much appreciated.
Old 26th March 2012
Flame__'s Avatar
Flame__ Flame__ is offline
Sportster/Buell Year: 1989
Sportster/Buell Year #2: 1998
Other Motorcycle Year: 2000
I would re-seal it! But screw the radiator place, just do it yourself! Buy some Redkote and follow the instructions. Don't use Kreme coat!
Knees in the breeze.
Gamertag, PS4: Bikerdude__
Old 26th March 2012
salrosa's Avatar
salrosa salrosa is offline
Sportster/Buell Model: 1200c
Sportster/Buell Year: 02
salrosa is on a distinguished roadsalrosa is on a distinguished road
I would seal it just to be on the safe side. Here is what I just used over the weekend. It's pretty easy but there is a lot of drying time in between steps. It took me all Saturday to complete. They had it shipped to me the next day too.
It's the same as Red Kote. I bought the complete motorcycle sealer kit.
http://www.4secondsflat.com/Fuel_Tank_Sealer.html
Old 26th March 2012
thanks for the ideas!
I've did some more reading, and some guys say if the tank isn't already rusty you should be fine. My tank isn't rusted. They say if you always keep fuel in it, you should have a internal rust problem. Some say they never coat their tanks...
It's risky, but I might just leave it as is. I don't want to pay for the radiator place to do it, and I've heard horror stories about sealer kits you can buy. Knowing my luck, I'd make things worse by trying to seal it myself.
Old 26th March 2012
salrosa's Avatar
You could always run it without sealing then if you an issue later
PUll it off and coat it.
Old 27th March 2012
Yep. I think that's what I'm going to do.
Thanks!!
Old 27th March 2012
tmack-1's Avatar
tmack-1 tmack-1 is offline
Sportster/Buell Model: Sportster XLH1100
Sportster/Buell Year: 1986
Other Motorcycle Model: Speedway Green Horm
Other Motorcycle Year: 1972
tmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to alltmack-1 is a name known to all
Metal tanks have a "patina" (I think I spelled that right) on the metal that helps slow down rust. Welding will do some damage to the patina but not as much as sandblasting it. They do make a rust removers that also restores the patina.
The one I used ( there must be others) is not cheap. "Rustol" ( http://www.sudco.com/rustol.html ) , around $47 a quart last time I bought some. Good part is that it mixes with water (5:1 or 10:1 depending on how much rust you want to disolve ) and it can be re-used up to 5 times.
1986 XLH 1100 (fixer-upper) // Engineers design things, Technicians make them work. --- 30% of being mechanical is confidence/30% is knowing to go slow when needed/30% is looking repeatedly at what you have/10% is dumb luck .
