0 New in NM
Last Post: Vohnsen
0 C.O.B.B run west
Last Post: Zoharo
0 Kickstand identification?
Last Post: cotton1
Last Post: Vohnsen
0 Whats a bigger priority - FF or W/shield?
Last Post: sltm1
0 What's your helmet?
Last Post: Wharfcreek
0 Oil Dipstick with Temperature Gauge 63023-05
0 04 sportster custom 883, turn signal module (TSM)
0 Is there an 'easy' way to R&R the Turn Signal Module?
0 Silverado Power lock issues
Old 17th April 2012
russzx6's Avatar
russzx6 russzx6 is offline
Sportster/Buell Model: 1000cc Ironhead Sportster
Other Motorcycle Model: 96 KDX200 Dirt Bike
russzx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to allrusszx6 is a name known to all
Is that some sort of fine metal filing i can see over on top of the black bracket in your video?
24 beers in a carton. ...24 hours in a day . .. coincidence??
Old 17th April 2012
Hopper's Avatar
Hopper Hopper is offline
Other Motorcycle Year: 1942
So thats what life looks like if you are a rear cylinder on an Ironhead.
Sounds chain/sprocket related to me.
Old 17th April 2012
mikepeetz's Avatar
mikepeetz mikepeetz is offline
Sportster/Buell Model: 1974 Sortster
mikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nicemikepeetz is just really nice
Originally Posted by bobber58 View Post
Sounds to me like your chain is either rubbing on the hardtail crossmember or rubbing your rear fender. You don't have a cain tensioner do you? If you do it could have a bad bearing in it. If you dont the chain cam definately be dragging across the frame.
Ya i am running this chain tensioner... Is that what a bad bearing sounds like?
Old 17th April 2012
Hopper's Avatar
Lift the chain off the tensioner and spin the roller. It should spin free and without noise and without any notchiness. if you can feel any notchiness when you turn the roller, the bearing is toast. But that still might not be your noise.
Old 17th April 2012
shaymus's Avatar
shaymus shaymus is offline
Sportster/Buell Model: Sportster 1200 .030
Sportster/Buell Year: 1987
shaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of lightshaymus is a glorious beacon of light
I just fixed a similar noise and it was the chain rubbing the inside of the sprocket cover.
Old 17th April 2012
big andy's Avatar
big andy big andy is offline
Sportster/Buell Model: xlch 73
Sportster/Buell Year: sold
Sportster/Buell Model #2: 1997 1200s
big andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond repute
+1 on what hopper said
1997 1200s 1250 Hammer performance kit . Hammer performance billet inlet manifold .Hammer performance billet pushrod tube holders. energy one extra plate clutch kit . bronze oil pump drive gear upgrade
Old 17th April 2012
DirtyCory's Avatar
Sportster/Buell Year #2: 1972
Other Motorcycle Model: Sportster 48
Other Motorcycle Year: 2010
DirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud ofDirtyCory has much to be proud of
thats deffenitly a bad rod bearing.... you better tear the whole motor down!
If your gonna do something, do it right!
[SIGPIC][/SIGPIC]
Old 17th April 2012
randy3934's Avatar
Sportster/Buell Model #2: 1979 and 1969 XLCH
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1980
randy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud ofrandy3934 has much to be proud of
seems to occur when the rear wheel is turning, I'd get it off the ground and spin the rear wheel without the engine running, should be able to isolate where the sound is coming from easier.
Old 17th April 2012
mikepeetz's Avatar
I tried that but i could not get a sound like that.or anything even close...
Old 17th April 2012
scottfisher's Avatar
scottfisher scottfisher is offline
Sportster/Buell Model: FLCH
Sportster/Buell Year: 61
Sportster/Buell Model #2: XLCH Kit Bike
Sportster/Buell Year #2: 60
scottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to allscottfisher is a name known to all
do you have a bolt in this location that the chain is catching on:
it may only catch when you are under load. I have to grind some clearance off a regular grade 8 bolt not the hex head pictured which is obviously sticking out too far but this is what was used when the bottom end was rebuilt for me and if I wasn't paying attention I might have assumed would just fit in and not switched out.
Scott
'61 'CH
'60 'CH
See No Evo, Hear No Evo, Speak No Evo, Ride No Evo
