0 Fuel Pump Problems
Last Post: Blues
0 There’s shade tree brakes; then there’s the dark side of shade tree
Last Post: ss396
0 first engine start after rebuild
Last Post: Sprtstr1200s
0 Shovelhead forum gone?
Last Post: gpydeski
Last Post: JensWest
0 Did I buy the wrong length chain?
Last Post: 83XLX
0 Why does my kickstand do this...
Last Post: Heff
0 Whats a bigger priority - FF or W/shield?
0 Weld-on Bungs and Mounting Tabs for Your Motorcycle Build
Last Post: BILLETPROOF
0 New England 2018
Last Post: The Crusher
Old 5th May 2012
kj_walther kj_walther is offline
Sportster/Buell Model: ironhead
kj_walther is an unknown quantity at this point
Default 1975 ironhead coil help!
so i bought a 1975 ironhead and it has no electrical hooked up on it. I have the dyna s dual fire ignition in it and need to hook it to the coil, but the ironhead coil does not have a positive or negative mark on it. it is also custom mounted. is there any way of telling which side is positive and which side is negative. according to dyna website if i hook the blue and white wire backwards on my ignition it will fry it instantly. please help me figure this out. much appreciation.
Old 5th May 2012
typically looking at the tower holes, power is to the left and to ign control to the right.
Old 5th May 2012
ok so im looking at the coil laying horizontally and the tower holes to the top and the spark plug wires are facing toward me the positive is to the left or the right?
Old 5th May 2012
the stock coil has a hangar bar with two holes for the bracket to bolt to and the top of the bracket bolts to the frame above the front rocker cover. this bar is up and tower holes bottom looking at the coil from the tower hole side. power in to the left, ign control to the right. the ign control just grounds the coil so current can flow and chops the current to fire the plugs be it points or electronic. there are coiles available that have a different magnetic couple and it doesn't matter which is which but a stock coil is polarity sensitive.
Old 6th May 2012
You are being a great help, problem is, is I have a highly modified bobber that has the frame chopped and stretched so I have no clue how the mounting was. That's why I was refferring to the coil laying horizontally with the mounting holes up and the spark plug wires facing me. Is there any way you could tell me positive and negative that way? Thx alot for the help in advance, sorry for being a pain. I'm trying to save the 180 on buying a new dyna coil
I geuss where I'm getting confused is the spark plugs facing me or away from me? And then the positive and negative part from which way your looking at it.
Old 9th May 2012
still need help figuring this one out...... if im looking at the spark plug wires and the mounting holes are on top, coil laying sideways......... which side is positive, which side is negative..... i reallly wanna wire this thing up
Old 9th May 2012
best thing is to do image search say on google for a stock machine and see or the library as they usually have hd history books. lay the coil on the table, it can only stand up on way, tower holes down, same on the original, tower holes down facing rear. at work but i know someone out the has a picture that can help.
Old 17th May 2012
Guzzi850 Guzzi850 is offline
Sportster/Buell Model: 883
Other Motorcycle Model: Guzzi lemans
Other Motorcycle Year: 1976
Guzzi850 is an unknown quantity at this point
With the coil laying flat and the sparkplug wire sockets pointing towards the rear of the bike the positive terminal is on the left.
