Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Frame Mount EVO Sportster Talk (1986-2003 models)
0 Show your tank decals
Last Post: geoff
0 Lowboy frame conversion
Last Post: barefoot
0 '03 883 Hugger Odd Clutch feel, 1st gear jumps out
Last Post: Wharfcreek
0 Primary Oil INSANITY!
Last Post: cotton1
0 Cartridge Conversion?
Last Post: XLXR
Last Post: MXHD55U
0 Turn Signal Relocate issue
Last Post: Tucsonmax1
0 1979 oil routing diagram
0 Poll: how many people have/will trade(d) up to a new Sportster?
Last Post: The Crusher
Last Post: gravydog
0 Anyone still use Cycle Shack duels?
Last Post: Edster
Old 14th June 2012
Joe Promedio's Avatar
Joe Promedio Joe Promedio is offline
Sportster/Buell Model: XL 1200 Custom Dead
Sportster/Buell Model #2: 70 XLH Ironhead SOLD
Other Motorcycle Model: 2007 Dyna Low
Joe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of lightJoe Promedio is a glorious beacon of light
When you find out what it is, post it. That way anyone who has been having the same, or similar experience, will benefit from what you learned.
Thanks, Joe
Old 16th June 2012
potatox2's Avatar
potatox2 potatox2 is offline
Other Motorcycle Model: FLHT
Other Motorcycle Year: 2009
potatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the roughpotatox2 is a jewel in the rough
If it sounds kind of like you have taken a wet finger and run it around the rim of a wine glass, then it may just be some brake noise.
Old 16th June 2012
semjpm semjpm is offline
semjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to allsemjpm is a name known to all
To rule out the front brake, pry the pads back into the caliper and ride the bike without using the front brake. That should at least change the sound and give you an idea if it is the front brakes.
SEMJPM
Old 16th June 2012
potatox2's Avatar
On my 77 Bonneville and 80 Honda 750, they would suggest bleeding the brakes every now and then with a shim between the pad and the rotor. The honda even came with a shim in the toolkit. Cannot remember the size.
Old 17th June 2012
MacSporty02's Avatar
MacSporty02 MacSporty02 is offline
Other Motorcycle Model: FXDLI
Other Motorcycle Year: 2008
MacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant future
I was wondering the same thing about the belt to chain conversion, Years ago I had a metric with chain drive and it made a hugejass mess of the rear wheel from spraying chain lube on it. I was glad when the next metric bike I bought had shaft drive. I'm more than glad my Sportster has belt drive, in fact, I'm thrilled that the rear wheel stays so clean.
Old 17th June 2012
Just sayin...
Old 18th June 2012
Sportster1200C's Avatar
Sportster1200C Sportster1200C is offline
Other Motorcycle Model: Sprint 175SX
Other Motorcycle Year: 1973
Sportster1200C is an unknown quantity at this point
I plan on doing the conversion cause I want to eventually want to do a rigid with the old school look with the chain and all, I'm gonna try some of the suggestions with the front pads and have the front wheel trued to see if that makes any difference. It is a strange thing cause it went from riding home one night and everything being fine to this loud noise from the front end and I wasn't riding hard, no laying the bike over to hard in turns or anything just gradual cruising at 40 or 50 mph. I at first thought it was the wind cause it was about to storm but when I got to about 20mph with low wind and the clutch in you could still hear it.
I'll continue to update as I search for potential flaws that make this noise come about.
Old 20th June 2012
CharlieB's Avatar
CharlieB CharlieB is offline
Sportster/Buell Model #2: XLH 883 Deluxe - sold now
Sportster/Buell Year #2: 1986
Other Motorcycle Model: FXDWGi
CharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really nice
I had a noise... thought it was coming from the front brake... in fact, it was, just damned hard to find.
What mine was... was the !@#$@#$ anti rattle clip had come loose somehow. You'd look at the pads, fine. Braking effort and efficiency, fine. Noise. Just the clip.... mine lost spring temper and was more or less just a bendy piece of metal. New clip had lots of springy to it, and was a 5 minute fix.
