Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
0 '03 883 Hugger Odd Clutch feel, 1st gear jumps out
Last Post: Naplesron
0 K&N Killed It ! (custom filter)
0 Goldilocks Zone - 3 handlebar pics.
Last Post: Grumpy-Biker
0 Lowboy frame conversion
5 Which type honing tool for cross hatch ball or kind from harbor freight
0 Primary Oil INSANITY!
0 First gear no clunk or sound, normal???
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
Old 4th June 2012
morvenhouse's Avatar
morvenhouse morvenhouse is offline
morvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud of
Default Planning a rebuild this winter
I have a few issues with my 2004 XL1200R and plan to iron them all out with a comprehensive rebuild in the coming winter. Frame needs powder coating, jiffy stand bushes are worn and mounting corroded, starter clutch needs replacing, tyres need replacing, I want to polish the fork stanchions and the triple tree, fork seals could do with changing, will need new rear pads by then, front brake lines got a caution at the annual test so need replacing etc. etc.
As I spent most of last years summer running season sorting out various problems one by one, had the exhaust off three times, spending a small fortune on gaskets in the process it seems sensible to do it all in one hit, particularly as I have decided I want to keep it. Yes I know as soon as it is back together I will buy a new one, but that is my problem.
So I have read the rebuild stories, seen pictures of many owners garages that would put my Indy to shame, but do not really have much idea of the true magnitude of the task. I am an experienced wrencher but not on Sportsters. How long does it take (hours) to get to a bare frame and would you suggest I remove the obvious major sub-assemblies (triple tree and forks, engine, etc.) so I have reference points on which to focus my work or go for a total tear down? I plan to replace all wear parts during the rebuild (rubber mounts, head bearings, swinging arm bearings, rebuild callipers any corroded/worn bolts etc.) is there anything else which should get my attention whilst it is disassembled? I do not plan to touch the engine, except for a new starter motor or clutch. Whilst on that subject any opinion on either replacing the starter clutch with a HD replacement part, an All Balls clutch, or All Balls or Twin Power replacement starter motor?
Any advice greatly appreciated.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
Old 4th June 2012
lynched1's Avatar
lynched1 lynched1 is offline
lynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nicelynched1 is just really nice
I would suggest some tackle boxes to store nuts and bolts. Use some tape or drop in pieces of paper to label the bins / compartments.
I'm in the middle of restoring my 72 Torino and I found that piece of advice to be priceless.
'05 1200R
Old 5th June 2012
xlron's Avatar
xlron xlron is offline
Sportster/Buell Model: 1100
Sportster/Buell Year: 1987
Sportster/Buell Model #2: 1000 xlh
Sportster/Buell Year #2: 1980
xlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to allxlron is a name known to all
If your'e powder coating the frame? You must tear down "all the way". about 4 hours, and lots of blue painters tape & a sharpie to i>d everything thats comes off. no biggie. Then tape off the bearing houseings everywhere before taking to the powdercoater. And if you don't have the manual, get it, cause you will forget something along the way. Have fun bo.
Old 22nd June 2012
Collinspc Collinspc is offline
Sportster/Buell Model: looking
Sportster/Buell Year: any
Collinspc is an unknown quantity at this point
Let the coater tape or plug everything. Mark what needs to be covered or protected and the coater will use heat resistant tape, plugs or covers. Cost of masking is usually included unless it is a big masking job.
Old 22nd June 2012
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
I put all the fasteners back in the parts where they belong.
I tape my parts with masking tape, take photos and give my power coater detailed written instructions and he does a perfect job not coating what I don't want coated.
Old 26th June 2012
Thanks Guys, really useful info. When powder coating the frame do I mask off the VIN number plate and other HD markings which identify the bike? The areas around the various markings are in A1 condition so it would not impact on the overall appearance of the finished job.
