0 Need advice (Falters When Turning Corners)
0 Spokes or Mags
0 -75 ironhead, My first HD
Last Post: brianbbs67
0 Riding on Blood Thinners
0 Touratech Destino Boots Review
Last Post: MotoMoshe
0 Lowboy frame conversion
Last Post: barefoot
0 How do you upshift?
0 Oil Hose replacement help.
Last Post: Jollly Rogers
0 Stage 1 results
Last Post: 09Nightsterrider
0 Want to buy: solo saddle bracket and hardware
Last Post: Dsantizo2
0 Forty-Eight Special and Iron 1200 Sportsters announced today
Last Post: Jheitt
0 Solar battery charging
Old 11th July 2012
Benoit Benoit is offline
Sportster/Buell Year: 1982
Other Motorcycle Model: Lambretta innocenti 150cc
Other Motorcycle Year: 1959
Benoit is an unknown quantity at this point
Default I ruin my carb
I'm new in Harley, I just post to present myself few minutes ago. So I just bought a SLX Roadster 1982, 1000cc. I want to say, my english is not so good
Beacuse I'm french.
The problem was the carb, a B83F: I open it and the accelerator pump was broke. So I change it and, put everything back together. But I push my luck to much.
I follow some instructions on a thread from an other forum: tuning a keihin carb butterfly...I drill the SMALL screw on the carb, but it seem I'd ruin my carb! The small screw hide a flow chamber for the gas...
No screw there to adjust
Now I'm looking to buy a Mikuni vm38-9 carb. But to install it on mine, I have two cables for acceleration insted of one. Is it a problem to fix it or is it better for me to put a hsr42 with the dual cable ? And if it's easy to put the vm38-9 is it also easy to put the flat tm38-86 and tune it ? Thank you very much for your help.
Benoit
Old 11th July 2012
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
Here's the sticky for carbs: http://xlforum.net/forums/s...d.php?t=642408
Old 12th July 2012
Thank you I'll send it there...
Old 12th July 2012
72 Ironhead XLH's Avatar
72 Ironhead XLH 72 Ironhead XLH is online now
Sportster/Buell Year: 72
Will send both versions that might help you in the future.there is a program you might have available.It translates for you. type in your native tongue and have it translated to any other language.
Old 12th July 2012
http://www.microsofttranslator.com/D...ef=IE8Activity
Enverra les deux versions qui pourraient vous aider dans le future.there est un programme que vous ayez disponibles.Il se traduit pour vous. tapez dans votre langue maternelle, qu'il traduit dans une autre langue.
Old 19th July 2012
Hello, thanks for the information. I will try it now. Finally I found a used carburetor on Ebay. It is the same B83F on my motorcycle. Thus I retains its original character. I look forward to receive it by express post.
