Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Suspension, Frame, Forks, Fuel Tank, Oil Tank, Fenders
0 1968 XLCH Oil Leak
0 Sportster or Street Bob
Last Post: Bone
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 no rear brake light
0 2016 48 Hesitating
Last Post: 201648Rider
0 antique plates and insurance
Last Post: 60weight
0 New member in MD
Last Post: xraytoken
0 Help me with gas cap...
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Kicker shaft recommendations
0 Cad Plating
Last Post: conv90
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
Old 13th March 2011
Johnny Ableto Johnny Ableto is offline
Sportster/Buell Model: Buell X1
Other Motorcycle Model: Yamaha TDM850
Other Motorcycle Year: 2000
Johnny Ableto is an unknown quantity at this point
Default X1 fuel filler cap sticking
The filler cap on my X1 has always been a bit fiddly, but I had the cap flange and rubber boot off recently and after re-fitting the cap is almost impossible to latch closed or unlatch.
Anyone had that problem and found a cure for it or found another cap to fit (keyless would be ok)
Thanks,
John
I don't care what kind of helmet Kenny Rogers wears.
Old 15th July 2012
Jiggy Jiggy is offline
Sportster/Buell Model: Lightning Mellinium X1
Jiggy is an unknown quantity at this point
Not sure bud, but I went to remove my cap on my 2000 X1 and It simply will not release, after popping the tab and unlocking it the release mechanism will not seem to release. If I hear anything I will definitely let you know and hopefully likewise
Old 5th September 2012
Hey Jiggy,
try taking the tank off and turn it upside-down to wet the cap and boot with petrol, mine seemed to get better if I kept the tank pretty full and used it more often, which may mean the rubber boot was drying out and sticking?
John
Old 28th September 2012
HybridMomentsPass HybridMomentsPass is offline
Sportster/Buell Model: Buell S3 / Buell 1125R
Sportster/Buell Year: 9908
Other Motorcycle Model: Kawasaki KLX140L
Other Motorcycle Year: 2008
HybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura aboutHybridMomentsPass has a spectacular aura about
common problem on the tube frames, sucks.
Mine did it, I took off the locking mechanism completely.
Fortunately for me its on a dragbike, so I just use a piece of duct tape to secure it down now.
But I was at the track when mine gave up the ghost, I had to remove the 6 allen bolts and take it apart that way.
Look on badweb, more info about this problem there with solutions etc
https://www.youtube.com/user/garrettxowens 99 Buell S3 - drag / 08 Buell 1125R - street
