Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > VENDORS > Ricor Racing Shocks
0 Engine dies when choke off
Last Post: 60weight
0 Help please...77 xlch oil line routing diagram image?
Last Post: 69sscamaro
0 Won't rev past 1200
Last Post: Aocasio
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
Last Post: Hank21113
0 Well, damn. Cracked bracket.
Last Post: halfmt1
0 2nd year in a row paid member
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 Future of the sporty?
0 newby from Australia
0 About to buy an FP3. Any reason I should not?
0 HAMMERPerf 90" In the Works
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 Low Fuel Warning Light is still on
0 too bad
Last Post: Dave L
Last Post: Dave L
0 Another fouled plug puzzle to help solve
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
0 Ebay Guantlet Fairings or Burly Outlaw Fairing
Last Post: jzink0883
Old 26th February 2012
PiousDevil's Avatar
PiousDevil PiousDevil is offline
Sportster/Buell Model: 883->HP1250
PiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant futurePiousDevil has a brilliant future
Default Ordered some Intiminators
also ordered some progressive front springs on the cheap. At 195 pounds, is it appropriate to use both in conjunction?
Always thinking 360°
Old 27th February 2012
boro boro is offline
boro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to beholdboro is a splendid one to behold
Shouldn't be a problem using them both, as long as you're happy with sag and rebound. Seems some like straight rate springs with intiminators. Racetech lists .887 spring rate for 190lbs. H-D spring rate is .350. With intiminators and stock springs, I don't get enough rider sag or travel. Brian, at Ricor is very helpful.
Old 21st June 2012
terroristone's Avatar
terroristone terroristone is offline
terroristone is an unknown quantity at this point
any updates?
T1
https://www.facebook.com/AACustomCyclesAndy
Old 22nd June 2012
PiousDevil's Avatar
honestly, I don't have enough experience on a motorcycle to give a good critique, but my front end feels good, very solid and stable, tracks well, eats bumps (though I felt a bit squirrelly one night when I can upon a stretch or road that had been ripped up
for repaving suddenly at about 70, I'm sure it would have been worse if my front end were stock.)
Added a set of Pirelli Night Dragon tires a couple weeks ago, and put a superbrace on yesterday (not that I felt like my front end needed much improvement at this point, but it was on my list and I figure it can't hurt, right?) My front end should be about as good as you can get with the stock sportster forks.
The biggest challenge now is trusting my own work. I'm not yet fully convinced that my front wheel isn't going to fly off at any moment.
Old 15th July 2012
i ordered some as well, just waitin for them to get here (australia) i cant make upo my mind if i put the stock springs back in or leave my Ikon progressives....
T1
