Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 Curious as to what I actually have
Last Post: JakRabbit
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 How to make my Sportster 48 XL 1200X into a torque monster?
0 THE Trainspotting Thread
0 1200 heads in stock 883 bottom?
0 Goldilocks Zone - 3 handlebar pics.
Last Post: Dave L
0 Need help with glare.
Last Post: Dave L
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 Fork Brace worth the bucks???
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Last Post: tvon
Old 20th July 2012
threat357's Avatar
threat357 threat357 is offline
Sportster/Buell Model #2: 1200 CHOP PROJECT
Sportster/Buell Year #2: 1997
Other Motorcycle Model: 1200 CHOP PROJECT #2
Other Motorcycle Year: 1992
threat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to all
Well, you've both given me some good helpful info to think about and for that I thank you. Guess I've just gotta figure out now which cam between the .497 and .551 would best suit my needs as a streetable cam that will give me the bump I'm lookin' for. I'm still leaning toward the .497, just nervous about clearance.
Sent from my DROIDX using Tapatalk 2
Old 20th July 2012
threat357's Avatar
Ha! The kicker is that I've got an almost brand new set of "E" cams straight out of an XB on my workbench, and would be smart enough to install 'em in the right order (backwards from the buell) but not smart enough to figure out how to properly time them with the timing marks being off between buell and xl. Damn it.
Old 20th July 2012
1250IRON's Avatar
1250IRON 1250IRON is offline
Sportster/Buell Model: Iron
1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light1250IRON is a glorious beacon of light
I'm happy with the seat of my pants dyno on the .497's in my build.
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
Old 21st July 2012
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
The N4's while "drop in in most cases have been know to give problems when combined with the pistons you have in mind AND the late model 1200 heads because of limited eyebrow clearance needed for the larger valves in the 1200 heads.
The se conversion dished piston is intended for use with the 883 head.
I know this does not address your specific combination, but it is food for thought if you ever decided to go with 1200 heads down the road. The 1200 heads combined with dished pistons, give the additional problem of lower than optimum compression.
Old 21st July 2012
threat357's Avatar
No, I'm not planning on installing 1200 heads. I want to keep the 10:1 pistons and 883 heads that I've got now. I read through all 52 pages of threads in this sportster bottom end forum, and it seems like the best I can get is "yeah, they SHOULD bolt in with no problems, but maybe not. Most threads just die off and nobody posts updates (for the most part) after they have done the mods.
Old 21st July 2012
1250IRON's Avatar
Well that is really how any of these upgrades go. if your changing something for a bolt in and not checking your clearances your just asking for problems. my se.497 cam #3 rubbed on the inner case when the stock cams didn't. Dan at NRHS said he had never heard of this happening. you could plainly see that the #3 pocket machined into inner case for cam clearance hadn't cleaned up as well as the others. i have worked in an Aerospace CNC machine shop making aerofoil fan blades for commercial and military jet engines for 15 years. believe me when i tell you tolerances can vary a lot from one machine to another or even from spindle to spindle on the same machine. many many things can effect this. human error loading the part, air temperature, poor cutters ect... so check every clearance wether it is bolt in or not. When you are talking measurements in the thousand of an inch it doesn't take much to be out of tolerance.
Old 22nd July 2012
threat357's Avatar
Yeah, I intend to check my clearances, and understand that just because shit fits well on one bike doesn't necessarily mean it will on another of the same kind. I'm basically just tryin' to see if people have been running the .497's on the rubbermounts generally without problems and fitment issues before I shell out a couple hundred bucks and spend an afternoon tearing into my motor cuz it's my daily ride.
Old 22nd July 2012
threat357's Avatar
I do appreciate everyone's input here thus far. I know there's an endless supply of bad information on the interweb. Seems this forum has more legitimate trustworthy info then elsewhere.
Old 23rd July 2012
1250IRON's Avatar
If you need a fast answer with accurate info and no b.s. this is the best site. especially if it concerns info on motor work. much more performance knowledge here.
Old 19th October 2012
somebodyelse somebodyelse is offline
Sportster/Buell Model: xl1200l
somebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of lightsomebodyelse is a glorious beacon of light
Same boat here can't find full finished threads. I want to put Andrews cams in a stock from factory 2007 xl1200 with stock 1200 heads. what mods required to install Andrews n4 cams and Andrews n6 cams. will either if these bolt in I'm concerned with piston to valve clearance. I currently have the stock piston and stock w cams. Did any body do this 04 and up and have issues with piston kissing valves or success?
