0 '89 Sportster 1200 Chopper
0 Bikes and Bells and Bears
0 Engine dies when choke off
0 rpm jump pulling in clutch
0 Value of a Boattail?
0 New to Harley
0 Curious as to what I actually have
Last Post: JakRabbit
0 1967 XLCH stroker project
Last Post: Keithybloodygeorge
0 79 ironhead
0 Head gaskets.
0 Stock 883 cold blooded
Last Post: oldboy
0 How to make my Sportster 48 XL 1200X into a torque monster?
0 THE Trainspotting Thread
0 1200 heads in stock 883 bottom?
0 Goldilocks Zone - 3 handlebar pics.
Last Post: Dave L
0 Need help with glare.
Last Post: Dave L
0 99 1200s clutch drag
Last Post: jordan1200
0 Not charging issue!
0 V&H Shortshot question
Last Post: lucifer_mr2
0 Fork Brace worth the bucks???
0 1977 Bright Blue
Last Post: Jowniofownio
0 z bars
Last Post: jharback
Last Post: tvon
Old 16th November 2006
Dubfire's Avatar
Dubfire Dubfire is offline
Sportster/Buell Model: Used to ride a XL1200C
Other Motorcycle Model: Moto Guzzi Breva V1100
Other Motorcycle Year: 2007
Dubfire is on a distinguished roadDubfire is on a distinguished roadDubfire is on a distinguished road
Default That Was Then....This Is Now
Just a couple of before and after pics to show the modifications I have made to my Sportster since I bought it 2 years ago.
November 2004
November 2006
The bike had already had the Stage 1 tuning with the SE Baloney cut pipes fitted so the first thing I did was change the tyres, replacing the old, hard, cracked Dunlops with new Avon Venoms. The braided front brake line was next, followed by the Teardrop Air Cleaner.
Next came the LePera Maverick seat and removal of reflectors and lower belt guard. Longer rear shocks and progressive front springs were fitted and the bike was levelled by raising the forks through the clamps by 3/4".
A Wilwood front brake caliper and relocated front turn signals complete the changes to date. (I've also changed the horn, but you can't see that !)
Mike
XL1200C
Gone Gone is offline
How is the Wilwood caliper working for you, Mike?
Dubfire's Avatar
Thanks for asking Chris. It seems to be getting better every time I go out! I wanted to wait before commenting on it because after I first fitted it I found it to be not much better than the original caliper. But after leaving it overnight and bleeding the fluid again, braking improved, even though only a few tiny air bubbles came out. Now that the pads are bedded in, I feel that the caliper is now performing well and is definately a big improvement over the stock item. The speed-bleeder is a revelation! It really makes bleeding the brakes a doddle! Another happy Trak-Tek customer .
Excelent. Glad to hear it.
If you're still getting air out of it, it still might not be bled fully. Getting the air to go all the way down the caliper, turn the corner and head back up to the bleeder can be a challenge.
Sometimes it helps to unbolt the caliper and hold it level while bleeding. Not sure if I mentioned that back when you bought it. But, if you're getting good results from it, you may have it fully bled already.
Thanks!
Gyahmers's Avatar
Gyahmers Gyahmers is offline
Sportster/Buell Model: 1200 XLC
Other Motorcycle Model: 2007 Dyna Street Bob
Gyahmers is an unknown quantity at this point
Nice job, I wish I could keep my bike that clean.
Although I don't have a Wilwood brake caliper, (Btw, I really like the look of it. Might change mine out one of these days.) I do use a four piston caliper and really like the braking, big improvement.
Dubfire's Avatar
Thanks. You should have seen the bike before I washed it!
I'm sure you're right, i've heard that the 4 pot caliper on the 2000 on bikes is a big improvement over the single pot lump that was on mine.
XLFREAK XLFREAK is offline
XLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really niceXLFREAK is just really nice
Nice bike and nice work.
Yes the 4 pot caliper is very good the only draw back is that the pads are thiner and wear out quicker. but the difference between the 2 is night and day. and thay are way better than the old drum brakes from back in the day.
I hope to upgrade to dual set up one of these days.
Dubfire your changes are very nice. good work.
Dubfire's Avatar
Thank you.
I thought about a dual set up (together with changing to a 19" wheel, which I may still do) but for now the cost is prohibitive. Another caliper, a fork slider to mount it on, rotor, brake line, master cylinder, etc....it all adds up!
Sundance: thanks for the compliment.
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Bike looks great Mike, I really like the S&S!
