0 final drive front sprocket change
Last Post: lostNdallas
0 Swing arm bearing change
0 Non-Starter, Compression Test Results
0 xl1200T
Last Post: luce26
Last Post: Maxwell#256
0 Backfiring
Last Post: David Kirkha
0 New here - compression test produced meh results.
Last Post: rocketnorton
0 What to do now? Ironhead clutch hub nut stripped
0 S&S Super E
Last Post: Serious Blac
0 Iron 2020 wire tuck
Last Post: Dorretje
0 Exhaust paint, coatings for head pipes?
Last Post: SLW210
0 1970 XLH Tach cable kinked
0 Swingarm Fitment
Last Post: SLW210
0 1970 XLH smoke from rocker box gasket
0 What Is the Advantage - Shovster?
0 WTB 04-06 intake manifold
0 Steering Neck Tapered Bearin Kit
Last Post: SportsterXLCH1967
0 Canadians for sturgis 2021
Last Post: Knuckles
0 Fuse Box Pictures Wanted
Last Post: Blacky
0 2009 883 Wheel Issue
Last Post: Blacky
0 Iron 1966 XLRTT
Last Post: Model H
0 S&S Super B help
0 2018 Iron 1275 Project
Last Post: yelladox
WinXP (70), Maggie (64), grancan1 (56), SRKASM (50), metalmessiah, o113attitude (46), stinkynate (38), wingman_214 (37)
Old 14th May 2018
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Model: XLH Sportster
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Default Access to Battery Posts
On my late 84 model with the battery on the left side of the bike, I find it hard to access the battery terminals to charge the battery or put it on a tender without pulling the seat or the battery cover.
Do any of you have any special contact points around the bike that you've installed to make charging easier?
Old 14th May 2018
ryder rick ryder rick is online now
Battery tenders come with a pig tail you install for easy charger connections.
Old 14th May 2018
83XLX's Avatar
83XLX 83XLX is offline
Sportster/Buell Model: XLX-61
Sportster/Buell Year: 1983
Other Motorcycle Year: 1969
I just take the seat off - it's only one screw...
But, as ryder rick said, a lot of chargers come with a pigtail connector you can permanently attach to the terminals. Of course, then you have it dangling somewhere. That's why I just take the seat off.
Old 15th May 2018
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
I prefer to have the pigtail "dangling somewhere"
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
Old 15th May 2018
Yochstein's Avatar
I don't mind tucking away a pigtail. Taking the seat off gives me the minimal access to the positive terminal which I've arked a few times. I thought about fabbing a small cable with a protective end that I can hook my garage charger to but that might be overkill. I'll just buy a tender and be done with it.
Old 15th May 2018
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
You can try clipping to the breaker post wire coming from the positive side of the battery. Not the load side of the breaker though. Gotta know what you are doing to try this though.
Ground can go anywhere. Except clipped to the tire.
Traveled to
Old 15th May 2018
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Other Motorcycle Year: 2014
Sadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud of
One thing to note about the tender pigtails...they have a 7.5amp fuse, and won't take a full load from a regular battery charger. They're meant for the trickle chargers or low drain power ports for phone/GPS chargers.
I've often run with the devil, but I've never made any deals....
Old 15th May 2018
Yochstein's Avatar
My battery was low from winter storage. I wasn't smart enough to think to purchase a tender for it last fall. I used my charger to get enough juice in her to get her to kick over and all was well. I'm just looking for an easy option to put my maintainer on without investing in a trickle charger.
Sometimes I make things more complicated than necessary.
Old 15th May 2018
Ah but, you could take the seat off once, install the pigtail and thence forward park and plug in. Here's where mine stays. It's out of the way and I forget about it until I need it.
Old 15th May 2018
Mine ended up below & to the rear of the battery box:
I also made some accessory items to make it more useful than just trickle charging...
http://xlforum.net/forums/showthread.php?t=2040129
2 Relax
FREE XLForum Organized Tech Info - Check Out The Sportsterpedia
