Last Post: VXDspud
0 Dreaded carb again
Last Post: VXDspud
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 1985 Ironhead, help with dynatek 2000 install
0 teflon buttons or circlips?
Last Post: rocketnorton
0 Intake Seals
0 Where To Get Free Air
0 Piston melted
0 Bob The Chicken
0 Please help with muffler identification
Last Post: mrmom9r
10 Introduction
0 82 XLH in Arkaksas
0 Venhill cable
Last Post: 93trident
0 Help & advice needed
Last Post: Andy Hog
0 My 99 883 c
Last Post: 99-883-c
0 Electrical problems.
Last Post: Andy Hog
0 New to HD
Last Post: Tyler45
0 Happy Birthday Crusty and Joes95bobber!
0 Cam followers have locked up internally. No movement at all. Why?
0 LED Headlight?
0 Anyone know who can shorten fork tubes?
Last Post: Whitewalls
0 changing from stock gas tank
Last Post: Edster
0 I was surprised Friday, would appreciate some input.
Last Post: Fivecats
0 PA/NJ Ironhead Gathering (Fall GBB) 9/18/21: (Photos, video, and story!!!)
Last Post: flthd31
PlanB, Cuco6924 (75), 1200sporty (64), iron68 (50), LifesHarlequin (37), mattosm (36)
  #91
Old 8th July 2018
rocketmangb's Avatar
I think if you look at the flanges the bolt hols are not centered
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 8th July 2018
Matt Black Matt Black is offline
Matt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant futureMatt Black has a brilliant future
You guys are great. I flipped my flanges, mounted the carb like before, tightened the flange bolts just enough to hold the manifold in place and then removed the carb and finished torqing the flanges.
Before:
20180706_202357 by David Arens, on Flickr
After:
20180708_111226 by David Arens, on Flickr
This probably also explains why when I removed the carb for the first time to rebuild it, I found I could wiggle the manifold about 1/8" up and down even though the bolts were tight. I guess it could have been why the original seals were trashed as well.
I'm waiting on a couple more things to come in (1/4" spring type hose clamps from Amazon and a custom length throttle cable from Barnett) and then I can continue to put things back together.
Thanks again.
Build thread: http://xlforum.net/forums/showthread.php?t=2030965
Old 8th July 2018
Just to complete the carb mods/repairs part of this thread, I followed the instructions on the CVP website to remove the old fuel elbow fitting. You basically break off the remaining plastic which exposes the inner brass tube. You use a 1/4-20 tap to thread the hole and then make a little puller with a 3-4in 1/4-20 bolt and a deep socket. Once I mocked everything up with the carb on the bike to get the new elbow clocked correctly I pressed it in using my bench vise. The whole operation was pretty straightforward and simple.
I should have mocked everything up better before pressing in the elbow, the angle I thought I would need ended up pointing too far forward and the Lowbrow/Gasbox carb support bracket blocked the fuel line. I had to gently twist the elbow counterclockwise from about 1 o'clock back to about 11 o'clock.
It did take some tweaking the length and routing of the line and the angles of the inlet elbow and the petcock outlet to get the fuel line to where it didn't rub anywhere.
I was also limited in where I could clock the petcock by the position of the selector lever interfering with the throttle cable. This won't be an issue if you use a different style petcock or your petcock is on the left side.
20180607_213024 by David Arens, on Flickr
20180706_195444 by David Arens, on Flickr
Old 9th July 2018
cotton1's Avatar
cotton1 cotton1 is offline
Sportster/Buell Model: 1200
Sportster/Buell Model #2: XLH 883
Sportster/Buell Year #2: 1998
cotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond reputecotton1 has a reputation beyond repute
Glad to see you are making progress man. As far as the tooling, I cut the end off a standard Allen wrench like IXL2Relax suggested. Works great!
XLF is the best Bro! Keep plugging, but keep us updated!
Cotton1
Sent from my XT1254 using Tapatalk
Old 9th July 2018
I cut one down too but I guess I didn't cut it down enough. It works great on the left side but it's still too big to get in when the carb is on.
Thanks! Progress is slow but sure. Coming up on one year since I bought the bike later this month. I've done a lot but there's still a ways to go. Tires and exhaust are going to be the remaining big ticket items, but there's a bunch of smaller stuff too. I'd also like to swap wheels to wire spokes, or at least get a mag for the rear instead of a solid but that's a want, not a need.
I was shooting for late summer / early fall but it doesn't look like I'm going to make it.
