Last Post: oupa
Last Post: oupa
0 Wet sump
0 While waiting on the paint to dry-and we thought it was the ballcheck
Last Post: Darkseacret
0 How to start a 1967 Sportster XLCH
Last Post: JackPrice53
0 XB9 crank?
Last Post: Curbside
0 Jutland 05-31-16
Last Post: slcharger
0 Hello from Murcia-SPAIN
0 XR1200 belly pan on an XL?
Last Post: CT XR rider
0 POLL: Vance and Hines
Last Post: Bama Lee XLC
0 And so it begins......
Last Post: Texassporty06
0 Spokes or Mags
Last Post: Desertfox
0 Spokes question
Last Post: Doc308
Last Post: Nayra
0 Fuel Pump Problems
6 Is Your SPORTSTER...
0 How stock is your bike
fhilliard (78), paulmo (74), Beloved (48), Mr. Cro (48), Chopper Duke (40), Danny3nose (38)
  #5491
Old 12th November 2018
newroadster's Avatar
newroadster newroadster is offline
Sportster/Buell Year: 2016
newroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud ofnewroadster has much to be proud of
Removed the tins to finally get them painted. I also I am going to add a smaller tooth front sprocket and a few other upgrades. I removed the rear foot pegs and found my exhaust bracket cracked.
ParrotHead's Avatar
ParrotHead ParrotHead is online now
I am the great Cornholio!
Other Motorcycle Year: 1974
Originally Posted by JackFrost71 View Post
Have you considered just building a table the same height? $50 or $60 bucks in lumber & hardware should do the trick
I have but a lift would be easier and I can pick up a used one for about $150. Would have had one this weekend if I had a truck to move it with
John Wayne - "The Shootist"
Crusty Crusty is online now
Sportster/Buell Model #2: XL1200 R
Sportster/Buell Year #2: 2005
Other Motorcycle Model: XLCH
Other Motorcycle Year: 1979
Originally Posted by dodgetrucken View Post
Had a little problem today when I went to put my 64 back together. I dropped the damn wrist pin clip down into the bottom end. I had to pull my raga to keep that from happening & forget to put them back. Now I have to pull it down.
Try using a telescoping magnet. It will probably pick up the clip and save you a lot of extra work.
Old 13th November 2018
dodgetrucken's Avatar
dodgetrucken dodgetrucken is offline
Sportster/Buell Model: xlh 900 custom
Sportster/Buell Year: 1964
dodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant futuredodgetrucken has a brilliant future
Yeah that's what a lot of my buddy's have been saying to do. I'm going to pick on up in the next few day. I hope i can fish it out. I do have a crack in the primary side case that needs welded up. The problem with it is that it goes threw a bolt hole... 1 out of 3 isn't to bad lol.
Sent from my SM-N960U using Tapatalk
ChinCactus's Avatar
https://www.harborfreight.com/Digita...era-62359.html
Hook, mirror and magnet accessories, video-out cable
These come in handy for a lot of things. Might be worth a try.
Wow that would be handy.
Subscribing Biker
I've found over the years, you can get all size magnets from old elec. motors. you can even cut or break them to the size you need. I've taped these to mechanics wire, zip ties, fishing line, wrenches, whatever it takes to get in there.
Ha, I do have some old speakers out of my old truck around here somewhere. I may try that as well.
Thanks for the ideal.
Old 16th November 2018
Alright... found it!
Subscribing Biker
I have the same magnet tool at work. Glad you found it!
Currently Active Users Viewing This Thread: 17 (0 members and 17 guests)
