0 Please help with muffler identification
Last Post: RKN
0 teflon buttons or circlips?
0 1985 Ironhead, help with dynatek 2000 install
Last Post: atengnr
0 Dreaded carb again
Last Post: VXDspud
0 Where To Get Free Air
0 I bought a Sportster last month, but I don't know what to do now, when it leaked the
0 Intake Seals
0 Piston melted
0 Bob The Chicken
10 Introduction
0 82 XLH in Arkaksas
0 Venhill cable
Last Post: 93trident
0 Help & advice needed
Last Post: Andy Hog
0 My 99 883 c
Last Post: 99-883-c
0 Electrical problems.
Last Post: Andy Hog
0 New to HD
Last Post: Tyler45
0 Happy Birthday Crusty and Joes95bobber!
0 Cam followers have locked up internally. No movement at all. Why?
0 LED Headlight?
0 Anyone know who can shorten fork tubes?
Last Post: Whitewalls
0 changing from stock gas tank
Last Post: Edster
PlanB, Cuco6924 (75), 1200sporty (64), iron68 (50), LifesHarlequin (37), mattosm (36)
Old 29th June 2019
brendan brendan is offline
Sportster/Buell Year: 1967
brendan is an unknown quantity at this point
Default Help identifying which keihin butterfly version I have and necessary jetting
Hi all,
I just bought a 71 900 Sportster and I am trying to identify which keihin butterfly carburetor it came with. When I opened it up it had a size 160 main jet and a size 75 intermediate jet, which in my research does not appear to be a stock configuration in any of the keihin butterfly models.
When I brought it home I had a pretty solid idle but at maybe half throttle in any gear it would just flutter and not make any power until I let off on the throttle again, turns out when I opened it up the main jet wasn't even seated in the threads, it just fell right out. I am thinking the previous owner hardly threaded the 160 main jet on instead of bumping up to a larger correctly sized jet.
I'm just trying to get a baseline on jet sizes to accommodate using this carb on my 71 900 with drag pipes, which is proving to be difficult as I don't know what jets came stock in this particular carb model and how they have already been altered. Any insight would be hugely appreciated.
Old 29th June 2019
Here are some photos of the carb - https://imgur.com/a/OZvcuGo
Old 29th June 2019
Imagine that, a jetting problem at half throttle with drag pipes!
Drag pipes suck!
This is a proper exhaust.
Old 29th June 2019
Drag pipes suck!
Just trying to work with what I've got...
Old 29th June 2019
I know of No way to fix it working on the carb. Many have tried.
Work on the exhaust, you can apply band aids but not eliminate the problem.
Stock head pipes and slip on mufflers is pretty good, I think the head pipes with the crossover might be better.
Some drag pipes will accept slip on mufflers but most get tangled up when the second muffler is added.
You might be able to do a stepped pipe with the drags but that is not as effective as a megaphone and has no scavenging effect (which is like free supercharging) a 2:1 will provide.
Old 29th June 2019
71 came with a Tillotson carb.
Here is the link to IH carbs and information in the XLFs Sportsterpedia.
http://sportsterpedia.com/doku.php/t...xhaust_systems
Keihin information is on that page also.
Old 30th June 2019
Sadsack's Avatar
Sadsack Sadsack is offline
Sportster/Buell Model: Xlh
Sportster/Buell Model #2: FX
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 2014
Sadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud ofSadsack has much to be proud of
A lot of us do that.
If your not into racing, or your not anal about impeccable tuning, you can tune the carb close enough to ride around the mid-range stumble. It's yours work on it ride it and enjoy.
I've often run with the devil, but I've never made any deals....
