Last Post: ZTatZAU
Last Post: ericfreeman
Last Post: Edster
0 Primary thread
Last Post: RandallM
Last Post: 11B40
0 weight loss thread
0 Massachusetts 2022
Last Post: t120r
0 "S" model specific Q&A
Last Post: heyjames
0 gasket sealant
Last Post: Jhbox13
Last Post: tiderider
0 Sportster Tracker Wheel and Tire Questions
Last Post: Big Al
0 Informed reviews!
0 Microsquirt EFI Conversion
Last Post: t120r
0 Rear Brake Squeal Fixed
0 Black Bike Bible
0 Allegheny National Park III
Last Post: sprink
Steph (56), yubman (51), Sporty1971 (51), Windesch (49), Mark_Bench (45), motherduce (43), sgtfry (40), Mrtechit101 (31)
Old 3rd November 2019
jsandidge's Avatar
jsandidge jsandidge is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Suzuki GS850GL
Other Motorcycle Year: 1982
jsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to alljsandidge is a name known to all
Default Cam chest vent hose
There is a braided vent hose going from my cam cover that ends at the back of the motor underneath the starter. It is just an open hose. It is an oily, greasy mess in that whole area of the bike. Is this normal?
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
That vent hose should go to the oil tank...
It has the pipe clamp on it in this pic [hard to see]...
It is the bottom one in this pic...
Does not run thru the hole in this pic...
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
jsandidge's Avatar
The hose I'm talking about is the breather hose that starts at the cam cover by the generator. About 10 o'clock on the round part of the cover.
doodah man's Avatar
that one was originally plumbed into the carb air cleaner. do you also have the cam chest vent (metal) tube at 6 o'clock? older bikes had only the 0600 vent and it would mist a small amount of oil while riding, but not a major oil slick. another thing you can check is that the end of the generator inside the gear case still has the oil slinger on the end of it.
SHAKY DAVE's Avatar
SHAKY DAVE SHAKY DAVE is offline
Sportster/Buell Model: XLX
Sportster/Buell Year: 83
Sportster/Buell Model #2: '85 ironhead drag racer
Sportster/Buell Year #2: xlh
SHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud ofSHAKY DAVE has much to be proud of
yep,normal
IronMick's Avatar
A very good idea is to run two vents, one from the 10:00 o'clock fitment and one from the 6:00 o'clock. On my 1980 I ran the stock type from the 10 to the back of the air cleaner, and a hose from the 6, along the rear muffler support to the back. It would only drip out a few drops when I parked the bike after a "spirited" ride.
The engine obviously ran more freely, a different, better experience.
jsandidge's Avatar
There is a plugged hole at 6 o'clock. I think I'll try the double vent like IronMick suggested.
Be aware that opening the bottom port in the breather on that model defeats the oil_drain_back feature. A hose connected to that position WILL dribble oil needlessly.
If the motor is pushing oil out the breather you have a ring seal problem or the motor is detonating. Adding a second breather hose will not fix that and in this case will let more oil escape.
Braided hose on a Harley sucks because the finish of anything the hose touches will get eaten away at due to vibration. Also broken wires will make you bleed and use bad words.
Old 4th November 2019
IronMick's Avatar
Be aware that opening the bottom port in the breather on that model defeats the oil_drain_back feature. A hose connected to that position WILL dribble oil needlessly...
I did not experience this with my 1980. Same for at least one other XLForum member.
As I mentioned above, the only dribble I got was minor, and only after the bike was parked after a "spirited" ride.
If/when you have your cam cover off you will see a tiny hole drilled at the bottom of the cavity that by-passes the check valve and drains any oil that collects in the cavity back into the motor.
