Last Post: kaveebee
0 2 Up Seat Recommendations
Last Post: ReddTigger
0 Bannana Caliper 73 XLCH- no brakes?!?
Last Post: JacksBrother
6 1973 Sporty - Starts, Runs Good, Stops...
0 Dunlop elite 4's?
0 C.O.B.B run west
Last Post: skien
0 Honda Nostalgia
Last Post: felis
0 2016 72
Last Post: 1up
0 New Photo Challenge: Show Us Your Bike Next to a Lighthouse!
0 Thought my clutch went out or tranny, was front pulley
Last Post: leo310
0 Electronic jet kit
Last Post: Jason's Sporty
0 Mikuni Carb vs Easy Kit
0 Primary/transmission synthetic oil
Last Post: XL Ed
Last Post: West Texas Buffalo
0 How old are you?
Last Post: RandyMac
0 Sturgis 2018
Last Post: the cowboy way
0 Plug wire question
Last Post: chris16371
0 Rebuilt solenoid now bike tries to start when I connect batt cable? Wtf?
Last Post: BrokenIron
Last Post: Roosterman
0 Any K model guys interested in cam regrinding?
0 Who can make a spare key?
Last Post: gravydog
0 Turn signal failure
Last Post: slamtry
0 Killer Instinct Unchained
Last Post: davixlrtt
0 ‘68 XLCH...transmission
0 Solenoid plunger boot super important?
Last Post: Windtheropy
0 Passenger floorboards and backrest questions
Old 24th September 2011
turkishxl883's Avatar
turkishxl883 turkishxl883 is offline
Sportster/Buell Model: xl883l
Sportster/Buell Model #2: 2008
turkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to allturkishxl883 is a name known to all
Default spark plug problem :(
today i changed my plugs but the problem is i use locktite not the strong one blue on it i mistakenly read the manuel wrong in the manuel it said use locktite anti seize
do i harm my bike or the threads? what should i do ?
wilkin4's Avatar
wilkin4 wilkin4 is offline
Sportster/Buell Model: XL1200 S/ sold
Other Motorcycle Model: Suzuki M109R/ totaled
Other Motorcycle Year: 2008
wilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond reputewilkin4 has a reputation beyond repute
Pull them out now, the longer they stay in the worse it will be. I think heat and time makes the locktite more hard. I would get new plugs, or clean the locktite off really good. Not sure if it will damage the threads, you may get lucky.
Just my 2 cents worth.
On the Highway to Hell, no stop signs, no speed limits.......
rocketmangb's Avatar
I would pull them out and replace with new ones using copper anti sieze
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
i pulled one out now it was hard but not that hard.but i guess some white small glue parts very small fall in to cyclnder but be ready i broke the spurk plug head on the first cyclinder (((((( so what now? damn locktite indeed damn my reading
Baphomet's Avatar
Baphomet Baphomet is offline
Sportster/Buell Model: XL883L/1200 (Sold)
Sportster/Buell Year: 08
Other Motorcycle Model: FXDWG (wide glide)
Other Motorcycle Year: 2015
Baphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond reputeBaphomet has a reputation beyond repute
Well, I was not the one that put my plugs in and when I went to remove them this happened.
I tried tons of ideas from the guys here and after breaking an easy out I gave up and took it to a shop and had them remove it for me.
Only cost about 60 bucks to have it removed.
Here's the tread along with all the suggestions I got. Good suggestions, but in my case they didn't work ... but they are worth a try.
http://xlforum.net/forums/s....php?t=1066281
oh this really helps i will try it on monday i guess tomorrow every where is closed.
But do the parts of the plugs did fell in to the cyclendir?
Tater's Avatar
Tater Tater is offline
Sportster/Buell Model: 1200 C
Sportster/Buell Year: 09
Tater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to allTater is a name known to all
WOW---I thought you may have just broke the porcelain off....
I finally washed my bike the other day and noticed that the +/- 1 YO NGK Iridium plugs had quite a bit of rust on them... I hadn't ridden in the rain and Lord knows I don't wash it but twice a year... Anyway I pulled them and cleaned them up good, then put some dielectric grease on them and anti-seized the threads good then reinstalled...
Don't know why all the rust, it's parked inside a dry hot shed...
Have a good one...Tater...
Sportster Owner/Rider since age 72...lol... Rider since Simplex...???
09-xl1200 "C" Vivid Black, Cast 19" Frt. Wh., Moded Stage 1+, X14iEDs, 29k + mi...
MicroTach +, Higher wider H-bars, Mustach bar Mtd. Hwy. pegs...
Viking Shock Cutout Saddlebags, Mustang Seat, Rear Mt. Signal Lt. Kit, SuperBrace...
Old 25th September 2011
damnnn me i need a eye correction also how can i read anti sieze as locktite blue
i dont know but who ever i talk to is tell me my job is hard
i need to take of the head and go to machine shop and taking head off is not a easy job i need new gaskets for it off off off
can not sleep all night thinking about how dd i do this wrong of my stupity.Someoe ounch me one the nose pls
Old 26th September 2011
MN Mailman's Avatar
MN Mailman MN Mailman is offline
Sportster/Buell Model: AMF XLS Roadster
MN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of light
Everyone does something dumb sooner or later. Get in a hurry, misread, whatever.
Don't sweat it; it's part of the experience.
No one got hurt, including yourself, that's all that matters.
This kind of stuff is to laugh at and have fun with, not beat yourself up about.
Question Authority
i talked a guy from ttcustoms they will send a van to pick up my bike they told me it got only 2 hours of job and dontt worry about ruining the cyclinder trust them i hope to get my bike soon its indeed funny haha
