Last Post: 45Brit
0 More of a reintroduction
Last Post: k9unitb
0 crack in head
Last Post: slamtry
0 Clutch Spring plate poll
Last Post: NZstu
Last Post: 45Brit
0 Is there a damn Tachometer on a 1970??!!
Last Post: kaveebee
0 Cylinder Piston kits
0 Bars on C Riser?
Last Post: mattjs666
0 Range With EFI 3.3 Gal Tank
0 1967 XLCH stroker project
0 stress killer
Last Post: moparnut72
0 05 and 73
0 Throttle cable(s)
Last Post: RussW
0 Fact or Fiction - HP Claims
Last Post: KCinSB
5 Am I looking for Trouble ?
Last Post: lew265
0 WTF Happened
Last Post: brianbbs67
0 The norse Saga's, or Pia & Tores ramblings if you like.
0 Feeling in trouble.
Last Post: sdsbassist
0 i need new bars please help!!!!1
0 Adapters to put a 19" on rear
Last Post: Guidry
Last Post: kaveebee
0 Brake light stays on
Last Post: 1980SPORTSTER
0 The White Bike is the Right Bike Thread.
Last Post: if6was9
0 81 ironhead gear oil large leak
Last Post: Slidesquad24
Old 24th December 2011
Slashkutt Slashkutt is offline
Other Motorcycle Model: HVA TE610
Other Motorcycle Year: 1994
Slashkutt is on a distinguished roadSlashkutt is on a distinguished road
Default Chain and sprocket combo
20 or 21 teeth on the front and 51 on the back is standard, right?
Does anyone know how many links to the chain go with that setup?
Any recommendation for chain: O-ring or else, specific brand?
Thanks!
Monte03's Avatar
Monte03 Monte03 is offline
Sportster/Buell Year: 1969
Sportster/Buell Model #2: 1966 XLCH
Other Motorcycle Model: BMW Twin
Other Motorcycle Year: 82
Monte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud ofMonte03 has much to be proud of
Default Chain n Sprocket
Thanks!
If your bike is the later Wet Clutch you can use an O Ring Chain, if early Dry Clutch the standard chain works best so that there is clearance behind the Sprocket cover.. the Heavy Duty or O ring are fatter and that becomes an issue if early dry clutch, I have used Diamond XDL also Tsubaki standard 530, about 110 Link and I fit it to size, some bikes have longer swingarms than early sportster so it's best to buy longer and fit the chain..
for all around use a 21 up front seems to be the popoular way to go with the stock 51 at back, if you go 19 or 20 it will be more peppy around toen but not to great on the hyway.. serious hyway touring you can go 22/23
I have the 21/51 on my 69 sportster and I like it...
Cycle World Oct 1962:
'The Sportster XLCH is not every Man's cup of tea - and we don't think it was intended as such'
Old 25th December 2011
106 links is standard length and should fit that combo.
joey81iron85 joey81iron85 is offline
Sportster/Buell Model: ironhead
joey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the rough
I like a long chain I fit it then break it to the length I need. I'd rather do it that way then to buy a chain that is to small. Get a breaker at harbor fr. For around 10 bucks or use a grinder carefully on the pin then pop the link off with a punch or screw driver
... Does anyone know how many links to the chain go with that setup? ...
Change in either sprocket size or chain links typically does not require a change in the other - unless perhaps your chain is too tight already and you are going to a larger sprocket.
