0 Kicker shaft recommendations
Last Post: brianbbs67
0 1972 tank fitment
0 New Front Rotor and Pads - Which Ones?
0 primary chain temp.
0 Crankcase Interchangeability
Last Post: x1_guy
Last Post: Crash7557
0 Dytch/Axtel Cylinder Identification?
Last Post: nakina
5 Transmission HELP!
Last Post: MatHormell
0 strange small wires attached to coil
0 90 in. Build
0 24633-77 Breather assembly
0 Everyone Should Read This ... (correct assembly and break-in)
0 Sportster or Street Bob
Last Post: Baby883
paulw666 paulw666 is offline
Sportster/Buell Model: 1200 custom
paulw666 is an unknown quantity at this point
Default tail light help
I purchased the road6customs model a tail light and license plate bracket. I got the license plate bracket on fine, but now I'm new at electrical things and I need some help, a lot of help haha
Here are some picture of my bike, I literally don't know where to start!
wagoneer12's Avatar
wagoneer12 wagoneer12 is offline
Sportster/Buell Model: Sportster 883C
Sportster/Buell Model #2: Chopped XLH
Sportster/Buell Year #2: 1967
Other Motorcycle Model: 2007 Road King Classic
wagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the rough
You need a manual.
I have done this before and started to type up a response....there is just WAY too much to type.
The fender, strut covers, turn signals, need disconected/removed. You need to splice the new taillight into the 'rear harness' that runs to the your stock taillight.
decide if you are bobbing the rear fender (most likely) and if you are running turn signals...etc....
Do you have a manual....? You can see how to disconnect all of the stuff and which wires to splice you new tail light into.
If you have a manual, I would be willing to talk to you on the phone about this. This evening.
I did this with a second fender, bobbed the end off where the tail light used to be. Cut the connector off that went to old taillight....spliced in the turn signals and new taillight. I also added a 'trailer connector' and switched the turn signals to red running/brake lights.
i am actually not available this evening, but i do have an owners manual. This seems like it will be a lot of work!
wagoneer12's Avatar
It's not 'too bad'. The biggest thing is....you are going to have that old tailights hole in the fender.
I highly recommend getting a second fender...or if you are o.k. with it....chopping your present one off at that point. Then just splice your new taillight into the rear harness.
