Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Electrical > Sportster Motorcycle Electrical and Ignition
0 Help please...77 xlch oil line routing diagram image?
Last Post: 69sscamaro
0 Won't rev past 1200
Last Post: Aocasio
0 Engine dies when choke off
Last Post: ChicagoSlim
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
0 HFSM issues with installing DK Customs push button on
Last Post: Hank21113
0 Well, damn. Cracked bracket.
Last Post: halfmt1
0 2nd year in a row paid member
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 Pictures of Sportster Scene 1960s
0 newby from Australia
0 About to buy an FP3. Any reason I should not?
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 Low Fuel Warning Light is still on
0 too bad
Last Post: Dave L
Last Post: Dave L
0 Another fouled plug puzzle to help solve
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
0 Ebay Guantlet Fairings or Burly Outlaw Fairing
Last Post: jzink0883
DIESEL's Avatar
DIESEL DIESEL is offline
Sportster/Buell Model: XL 883 C
Sportster/Buell Model #2: 2007 XL 883
DIESEL has disabled reputation
Default anyone used one of these batteries?
just curious
The only regret about the sporty, is that I didn't buy it sooner.
khaskins's Avatar
khaskins khaskins is offline
Sportster/Buell Model: Sportster 883L
Other Motorcycle Model: Honda CB350 Cafe Style
Other Motorcycle Year: 1970
khaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant futurekhaskins has a brilliant future
After having problems with 2 oem batteries in 5 years, I went back to HD batteries.
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
DIESEL's Avatar
I was just curious...I don't know what the stock dimesions are...
does our bike (2005 and 2007) take
YTX14ahl or YTX14L
Big-Ed's Avatar
Big-Ed Big-Ed is offline
Sportster/Buell Model: Sportster Sport XL1200S
Sportster/Buell Model #2: Fatboy 1450 FLSTFI
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Kawasaki KDX125sr
Other Motorcycle Year: 1991
Big-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to allBig-Ed is a name known to all
YTX14ahl or YTX14L
I thought the battery number for a 04-11 was YTX14L-BS (yuasa's battery number)
The size of the YTX14L-BS from yuasa is L-150mm x H-145mm x W-87mm (-/+ 2mm)
Terminal layout: Left = NEGETIVE & Right = POSITIVE + (With the terminals on the edge nearest to you)
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
morvenhouse's Avatar
morvenhouse morvenhouse is offline
morvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud of
+1 Yuasa YTX14L-BS. Note the ‘L’ designation is required so that the terminals are the correct way around. YTX14-BS is the same battery and cheaper but will not fit. Mine was installed 18 months ago, I use a battery tender during the winter and so far 100% performance with instantaneous starts.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
