Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle General Discussion and Problems
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
5 Metal Gaskets or RTV for top end?
Last Post: groovemeisterus
Last Post: rwharris
Posted On: 44 Minutes Ago
5 Who wants to guess what's trying to kill me on my bike?
0 5/6/18 - Keene Spring Motorcycle Swap Meet
0 New guy, first H-D, '65 XLCH, today......
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
0 Crankcase Interchangeability
Last Post: x1_guy
0 Masking stripes
Last Post: shooterj2003
0 no rear brake light
0 2016 48 Hesitating
0 Ei
  #51
Old 22nd June 2012
Gone Gone is offline
Yea I have a tach on my power vision tuner. As you can see I've never raced much. And RPM's makes me nervous.
Old 22nd June 2012
milmat1's Avatar
milmat1 milmat1 is offline
Sportster/Buell Year: 06
milmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond reputemilmat1 has a reputation beyond repute
A Note on Shifting, You want to shift at a point where you will be back at the bottom of the torque curve, Too high and you Bog, Too Low and you'll Bog.. It takes practice...
My bike is still pulling like a train when it hits the rev limiter so unless I watch the tach I will hit the limiter everytime....
Old 22nd June 2012
SomewhatLost SomewhatLost is offline
Sportster/Buell Model: 883 hugger/1190RX
Sportster/Buell Year: 1/14
Sportster/Buell Model #2: XLH 900 maybe...
Sportster/Buell Year #2: 1968
SomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really nice
don't fear the RPM's... they want to be your friend...
next time you are in a no-stress situation on your sporty, open it up a bit and let your sporty play in the +4K RPM's range... it will thank you for it...
actually if you had a solid mount evo, you would be able to see much easier/clearer just how happy those upper RPM's make it...
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Old 22nd June 2012
SuperTed's Avatar
SuperTed SuperTed is offline
Other Motorcycle Model: Fairlane 500
Other Motorcycle Year: 1964
SuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to all
Who needs a rev limiter anyway? Just one more un-needed thing to idiot-proof a Harley.
Please insert here:
- Poor attempt at cleverness/humor
- One too many quotes
- Oversized pic of my ride & lengthy list of upgrades
Old 22nd June 2012
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
I need a Rev limiter when I run my pump gas street sporty at the drag track.
Old 22nd June 2012
madnss's Avatar
Hold your throttle wide open, don't let off, fan your clutch as fast ad possible. Do that to redline, or wherever your bike runs out of power.
Old 22nd June 2012
I need a rev limiter too... at least in first, if I don't crank the throttle open fast enough I will get to my 7K rev limit somewhere around 1/2 throttle... actually it is usually a bit of a race to see if I can get to WOT before I start bouncing off the rev limiter...
Old 22nd June 2012
madnss's Avatar
I like to have it when I'm not at the track too. When the majority of time is spent over 5grand when riding, I hit it once in awhile
Old 22nd June 2012
also, just a a general, but mostly useless FWIW type thing...
from about 1957 to about 2001 (or to 2003 if you don't count the vrod) (and definitely not counting Buells...)
the fastest stock HD in the 1/4 mile for any given year was usually (always?) a sporty... if my foggy memory serves, generally by a good bit... like a 1/2 second or so faster then the next fastest model (usually the lightest Dyna?)...
so, you shouldn't be too surprised if your sporty at least keeps up... sporty's are pretty fast for girl's bikes
Old 22nd June 2012
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant future
nice going. That must have been fun to watch.
Sounds like his fist pumping was a triumph not for winning the race, but for being made only a little silly.
If he lost to a Sportster he would have looked real silly. He must have almost pooped himself at the site of you being in front of him.
I know I don't have what it takes to go 105.
